mobile external antennas
Submitted: Sunday, Mar 27, 2011 at 14:57
ltzgonow
Hi all, looking to upgrade to a new phone ( & plan) for the 4wd. comments about recent experiences with mobiles accepting an external antenna of say 6db or better for the 900mhz range. considering a multiband- (825 to 960) to also do the laptop. it seems
metro information is varied & coloured ( & old??). Ex
Adelaide for inland /outback points. Cheers, ltzgonow
Reply By: rooster350 - Sunday, Mar 27, 2011 at 15:11
Samsung C5220 accepts an external aerial and is a "blue tick " phone....the external aerial that I have also connects to the Telstra "elite" nextg modem that I use on the computer...the phone can also be used as a modem....do not know about the 6db or better bit , just that it works o.k. when we are camped along the
Murray river...cheers
449372
Follow Up By: ltzgonow - Sunday, Mar 27, 2011 at 15:22
Thanks will be checking out that phone.. just the sort of stuff we wish to know...cheers
721755
Follow Up By: Member - bungarra (WA) - Sunday, Mar 27, 2011 at 17:11
I second the above from first hand experience but also add the following
Post paid (plan) sim WILL work in that Samsung C5220 pre paid...we use that on the wifes phone because it is a better phone for us than the stupid one we got a plan
Also Telstra have them on a run out special at the moment for $69
They dont have any fancy things...just a good simple phone that works as good blue tick and receives a patch lead plug
721773
Follow Up By: ltzgonow - Sunday, Mar 27, 2011 at 17:23
Good, my wife is looking it up online, havent seen it over here, they seem to push the " tradies special" Nokia T90, not many of the newerones seem to have a patch line input. ...cheers & thanks.
721775
Follow Up By: BrownyGU - Wednesday, Mar 30, 2011 at 16:04
Itz,
I've got the Telstra (Tough)T90, very basic phone, but it has worked extremely
well on our tours around OZ, I've got a Little Devil antenna, with patch leads for the phone and laptop, recently in the
Flinders Ranges, I managed to get a couple of bars on the phone while at Rawson Station, speaking to another camper there, I think he thought I was Bull ....ing him, Our site was one of the higher positioned sites.
Cheers.........Browny
722122
Reply By: Robin Miller - Sunday, Mar 27, 2011 at 20:59
Its worth thinking thru what your whole goal is Itzgonow.
Noting wrong with C5220 but the external antenna connection is weak , and may not last long if you use the phone mobile.
One of
mine was in a standard aftermarket holder and when car went into a deep rut , phone came out and was held by the external aerial connection which promtly pulled the socket off the phones circuit board.
The connection would only be good for less than 100 uses anyway and the awkward positioning of it on this and similar phones makes it hard to use.
So if using it 4wding and you leave the car and wish to take phone its a bit messy.
The classic 6120 was being sold off cheap recently also , it has no ext ant , but performs about 3db better anyway.
If used with a passive coupler for ext connection ( about 3db loss over direct connection) then you get about the same mobile performance but its significantly easier to take shopping etc.
449405
Follow Up By: ltzgonow - Sunday, Mar 27, 2011 at 21:11
Hi Robin & thanks, the passive seems to make sense & is I guess more in line with newer technology, I do have concern with the fragile patchline on my wireless broadband dongle. What brand is the Classic 6120 & does it have blue tooth ?? Do you use the phone as a modem for your internet as part of a package when out & about ?? or a separate plan & modem ?? Thanks forthe direction.. Cheers.
721799
Follow Up By: rooster350 - Sunday, Mar 27, 2011 at 21:16
Not denying that this actually happened...the socket coming out of the phone...but having had this phone and a similar one and using the outside aerial on both phones...I do find it rather hard to believe that it could happen...but I suppose stranger things have happened........................
721804
Follow Up By: ltzgonow - Sunday, Mar 27, 2011 at 21:33
Yeh rooster350, ok I looked at both your profiles & you are really
well set up for the remote & rough stuff, I notice Robin was using an aftermarket holder which may have been diffrnt ??also driving conditions & style change and I am pleased to have all comments as I NOW tow ( more slowly) an ATV Caravan and do less hard rough stuff but still intend to get very remote,. at the end of the day there is always the H.F trans ( or UHF) but not WHAT i'M TRYING TO set up for now... they say the newer passive connections are ok & most new current Bluetooth phones do not do patch lines?? thanks again & cheers ...ltzgonow.
721807
Follow Up By: Robin Miller - Monday, Apr 04, 2011 at 19:00
In our coles
supermarket catalogue this week from thursday 7th (vic), the classic 6120 is $49 - to thinl I paid $300 when first came out some 3 years ago !
Geez i might get one just for parts.
722842
Reply By: Ozhumvee - Sunday, Mar 27, 2011 at 21:55
Nokia 6120 classic, works really
well both as a phone and modem, we've done both. Force make a cradle which allows in car charging, data connection and an inductive connection to the antenna of your choice.
We also use a bluetooth handsfree unit.
449415
Follow Up By: ltzgonow - Sunday, Mar 27, 2011 at 22:19
Ozhumvee, sounds like we are getting closer to the answers. I am out of contract & will soon upgrade. Sounds like telstra is the only answer, so the phone choice is all important. customer feedback iss adly still poor but coverage obviously good. Do you use a 900hhz stick or multi?... cheers and thanks. ltzgonow
721815
Reply By: TerraFirma - Monday, Mar 28, 2011 at 13:26
I use the a Telstra ZTE 165 series phone which has a pop up antenna and antenna external port. Via the external antenna we have been getting reception in areas where all else has failed. I use this phone as a Pre-Paid emergency device as my normal phone is an Iphone. There are various 7-9DB antennas with patch cable to suit a wide range of phones.
449460
Follow Up By: ltzgonow - Monday, Mar 28, 2011 at 13:35
Thanks TerraFirma, we will look this one up as it this is where we might end up going just for remote trips ! Cheers
721844
Follow Up By: River Swaggie - Wednesday, Mar 30, 2011 at 01:27
Hiya Terra
Looking at peoples reviews at the bottom of this link it sounds like you got a good one lol
Site Link
722054
Follow Up By: TerraFirma - Wednesday, Mar 30, 2011 at 01:36
Mine was a referb phone hasnt missed a beat, reception wise its the best thats why I bought it, $150 on Ebay. Yes I know the phone has had some issues overtime, perhaps I have been lucky, that said we go away as a group and you cant get reception unless you use this phone with an ext antenna, works as a modem to, for the price I paid been a great investment, not sure if there is anything better going around at the moment.
722055
