All Confused ..Can you Help ?????
Submitted: Tuesday, Mar 29, 2011 at 20:47
Chopperdog (WA)
Hi everyone
I am wanting to know if anyone can tell me an easy (Non Technical) way to test the Amps that my Engel is drawing using a Multimeter ???? I have done a couple of Google searches without much luck...
Hope someone can help me ????
Cheers Hilary ......
Reply By: Notso - Tuesday, Mar 29, 2011 at 20:54
If you know how to switch the Multi Meter to the Amp test. Do that and if you need to swap the leads do that.
Then if you have a Blade type fuze in the circuit that runs your Engel, pull out the fuze, insert your test probes across where the fuze usually sits, then turn on the engel.
The multi meter should show the amps being used.
449633
Reply By: Allan B (Sunshine Coast) - Tuesday, Mar 29, 2011 at 21:09
Hi Hilary,
First you need to switch your multimeter to the "10 Amps DC range". You will also need to shift the RED multimeter lead to the "10 AMPS" socket.
Then you must insert the multimeter probes "in series" with the fridge. To do this you must "open" the circuit and connect a multimeter lead to each side of the "break". To open the circuit you may need to lift ONE +ve wire from a terminal and place the multimeter leads ACROSS the break. Another way is to locate the fuse which feeds the fridge, remove it, and place the multimeter leads across the two contacts of the fuseholder.
AT NO TIME whilst the multimeter is in the 10 Amps mode should you connect its leads from 12v +ve and -ve or earth, or you will destruct the meter.
If your multimeter is a digital model there is no need to observe polarity (Which colour lead goes to which side) but if your meter is an Analogue model (with a scale and needle) then the polarity is important. If the needle moves downscale to below zero then simply reverse the leads for a reading.
449637
Reply By: nick b - Tuesday, Mar 29, 2011 at 21:15
if your topic related more to the problem you mite have more hits
WERE ALL CONFUSED AND NEED OF HELP
449638
Follow Up By: Chopperdog (WA) - Tuesday, Mar 29, 2011 at 21:57
No real problem nick ..Just want to know what amps im drawing so as to know what else i can safely run ..Lights for
camping and maybe another Engel on freeze on the odd occasion that i catch a fish or two ....
722035
Follow Up By: nick b - Tuesday, Mar 29, 2011 at 22:08
Hay Chopper , do what i do eat the fish and fill the fridge with deeeer !!!
722037
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Mar 29, 2011 at 22:11
How many
deer can you get in your fridge Nick? LOL
722038
Follow Up By: vk1dx - Wednesday, Mar 30, 2011 at 08:41
Chopperdog (unknown name)
We run two fridges, Engel 40L and 21L, two lights and sometimes an inverter to give us 240V for charging kids toy batteries. The circuit used for this is a fused one that comes straight off the batteries to the rear of the car.
We have matching dual Allrounder batteries connected in parallel and we very rarely stop for more than two nights. Plenty of grunt in the batteries to start the 4.2 TD diesel motor. The batteries are around 10 months old.
And sometimes I may also fire up the ham radio (similar circuit) and chat for a bit.
722065
Reply By: Rockape - Tuesday, Mar 29, 2011 at 21:44
Hilary,
if you are measuring the 12 volt side you will need a DC tester, your multimeter won't measure it.
Maybe easier to go to someone like battery world and ask them to test it, or look at the manufactures specs.
Have a good one
449646
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Mar 29, 2011 at 21:55
Hell Rockape, I HOPE he is measuring the 12 volt fridge supply, not the 240v ac supply. That possibility did not occur to me!!!!!!
But most multimeters, both digital and analogue, read 10 Amps these days. Or am I missing a point here?
722034
Follow Up By: Chopperdog (WA) - Tuesday, Mar 29, 2011 at 22:00
Yes Allan i am testing for DC Amps .....
722036
Follow Up By: Rockape - Tuesday, Mar 29, 2011 at 22:12
Chopper and Allen,
yep sorry about that, I just looked at my mulimeter and you can measure up to 10 amps DC.
Chopper you will just have to put the leads in the right spot and then measure the current in series, break the + wire and place the leads in between.
source +----------------. multimeter .------------------+ fridge
722040
Reply By: Allan B (Sunshine Coast) - Tuesday, Mar 29, 2011 at 22:09
Chopperdog,
Rather than trying to actually measure the current draw you may find it easier to go
HERE on the Engel site where the current for each current model is shown. If yours is not a current model one of the same size shown will draw about the same.
Note that for each model there is both a range of current and a maximum current. The variable in the range is due to the fridge temperature setting and the ambient temperature. In other words, the load.
449652
Follow Up By: Life Member - esarby (NSW) - Wednesday, Mar 30, 2011 at 15:32
Just looked at the Engal site and checked the 32 lt chest freezer.
it states that it will hold 44 x 375 mil cans. That all right for an Alcholic but it does not say how many Deeeer it holds.
722114
Reply By: Chopperdog (WA) - Wednesday, Mar 30, 2011 at 23:24
Thanks for everyones help (and some laughs) .Tried the Engel site but i wish to check for myself to see if they are talking porkies ....
Thanks again everyone .....
449780
