Large folding step
Submitted: Sunday, Apr 03, 2011 at 08:49
Member - Boobook
I am looking for a large fold up step for my Camper. I have one of those small gray folding ones you often see at Caravan Axccessory shops, and often called EZ step, and have looked at the Fiamma non folding step, but they are all about 210 - 220mm high leaving a big step up from there to the camper.
Is there such a thing as a decent, wide folding step that is about 300mm high?
TIA
Reply By: OREJAP - Sunday, Apr 03, 2011 at 09:26
Hi Boobook, You & me both. I had one of those plastic fold up steps....I think some outlets sell them for anywhere between $15 & $20
well mine just disinergrated causing injury to myself (minor). Apparently they are meant as a child's stool/step & not applicable for adults to stand on. Unfortunately no warnings on the one we bought so be careful if considering.
450151
Follow Up By: OREJAP - Sunday, Apr 03, 2011 at 09:43
Just found the type you mentioned on E Bay & they are 22cm high & support up to 136kg....about 4 times more expensive than the one we bought probly explains the structral failure on ours!!! I use the strong milk crate...not only can I store thing in it but I use it for she who is gravity challenged to use as a step to adjust the awning or whatever..I put a cover on the base of it & use it as a portable table too.
722611
Follow Up By: Member - Boobook - Sunday, Apr 03, 2011 at 17:25
Hmm not bad, I'll look at that. Thx
722676
Reply By: DoubleJ - Sunday, Apr 03, 2011 at 14:16
We have an EZ FOLDZ step, made in USA, very strong, height 23cm opened. I can't remember where we bought ours but it wasn't from CAMEC and much cheaper than their prices. I think I recall a larger size also being available.
450181
Reply By: Member - MUZBRY(Vic) - Sunday, Apr 03, 2011 at 16:32
Gday
If you Google Bunnings, then go to , builders and renovaters , scrole down to se some foot steps that might just do the job.
450200
Follow Up By: Member - Boobook - Sunday, Apr 03, 2011 at 17:26
Thanks Muzbry they are like ladders as far as I can see. I am just after a single step.
722678
Reply By: Shaker - Sunday, Apr 03, 2011 at 17:20
You could try calling Vista RV. They have a very substantial laser cut steel folding step, which I am sure that they would sell seperately.
450205
Worth following up, thanks Shaker
722677
Reply By: Tim Owen - Monday, Apr 04, 2011 at 20:07
I just got some of the blue ones from ebay from member vinracptyltd. They are rated to 150kg and are the only ones I could find that are @ 385mm high - perhaps too high for you.
450351
Follow Up By: Member - Boobook - Monday, Apr 04, 2011 at 22:09
Thanks Tim, I did see them but was worried that they were a bit unstable. Have it been ok.
722868
Follow Up By: Tim Owen - Tuesday, Apr 05, 2011 at 08:06
It is '
well built' (doesn't seem like it will crumble under you), but it is quite tall for its footprint - fine on firm flat ground, but it would topple relatively easily if tipped on an angle due to its height.
722876
Follow Up By: Member - Boobook - Tuesday, Apr 05, 2011 at 09:27
Thanks Tim,
It looks like a tall version of the one I have which can be a bit unstable too.
I think I will keep looking.
722884
