Solar Panels, Blocking Diodes??
Hi all, I have just wired in a Redarc BMS 1215 battery management system, which has the inbuilt MPPT solar regulator, this was connected to the existing 80watt solar panel. Previously finding the 80 watt a bit small, I decided to just paralleled in a 40watt panel.
My question is, do I need to add a blocking diode between the two panels? I assume one is not requried between the panels and the controller?
Chris
Reply By: Member - John and Val - Friday, Apr 08, 2011 at 17:57
Chriss,
Recommend just wire the two panels in parallel, i.e. connect their positives together, and their negatives together to function as a single big panel. You do not need to add any diodes anywhere.
J and V
- Albert Einstein
AnswerID: 450714
Follow Up By: Member - Chris & Debbie (QLD) - Friday, Apr 08, 2011 at 18:55
Thanks John, I had read on some sites that suggest using a diode to prevent problems with feedback from one panel to the other when in partial shade.
Chris
FollowupID: 723179
Reply By: Member - bungarra (WA) - Friday, Apr 08, 2011 at 17:58
You dont need blocking diodes between panels connected in parallel
As for if it is needed with that controller........you need to check that specific controllers specs
VKS 1341
AnswerID: 450715
Follow Up By: Member - Chris & Debbie (QLD) - Friday, Apr 08, 2011 at 19:11
Thanks for the reply, looks like I wont be putting any diodes in.
Chris
FollowupID: 723184
Reply By: S Paul - VIC - Saturday, Apr 09, 2011 at 12:36
There should already be diodes in the junction boxes of each panel ...
Steve
AnswerID: 450767
Follow Up By: Member - Chris & Debbie (QLD) - Saturday, Apr 09, 2011 at 13:30
Hi Steve
My panels do have diodes in the junction boxes but as I understand it they are by-pass diodes and not blocking diodes.
FollowupID: 723252
Follow Up By: S Paul - VIC - Saturday, Apr 09, 2011 at 13:36
They are diodes to stop current flow at night from the battery so maybe they are what you are calling blocking diodes ...
Steve
FollowupID: 723256
Follow Up By: Member - Chris & Debbie (QLD) - Saturday, Apr 09, 2011 at 13:47
May be wrong, but as I understand it, blocking diodes and bypass diodes are not the same thing. Blocking diodes prevent current flow back to the panels at night, while bypass diodes are connected across the terminals of each panel to shunt the current around a shaded, weak, or damaged panel when panels are connected in series for higher voltage systems than 12v.
FollowupID: 723257
Follow Up By: S Paul - VIC - Saturday, Apr 09, 2011 at 14:30
Ya learn sumthin new everyday here !!
Blocking Diodes.
While a solar panel "puts out" in sunlight, it "takes back" after dark, although the reverse current flow is much less. At the time of installation, a blocking diode is frequently added to the wiring to the battery. Such diodes are installed in addition to the bypass diodes found in some panel junction boxes and should not be confused with them.
A blocking diode has the effect of allowing the charging current to pass to the battery, but blocks any reverse current flow. However, such diodes cause a voltage drop of around 0.6 volts, which means that for a panel to remain an effective battery charging device, its output must now be rated at 14.6 to 15.0 volts. A 30-cell panel with a blocking diode, partictularly in a hot climate, will be almost compIetely ineffective; even a 33-cell panel will start to suffer a decline in its output as a battery comes up to charge.
Steve
FollowupID: 723259
