Caravan & Camper Battery Charging Feedback
My caravan is without batteries and has a 12V transformer (solarforce) fitted to supply 12V DC when the caravan is plugged into 240V mains power. I want to put a dual battery in my Prado. Will this aux battery run my 12 volt lights etc in the van. The van has a seven pin round plug. I'm not sure whether the van has two separate wiring circuits or not, one through the transformer for the van & the other through the plug to run trailer brakes & trailers lights. I only want to stop overnight at roadside stops occasionally. Any advice appreciated.
Reply By: Notso - Saturday, Apr 09, 2011 at 16:05
Do the van lights work when you have the van hooked up to the vehicle with no 240 volt plugged in?
AnswerID: 450777
Follow Up By: Notso - Saturday, Apr 09, 2011 at 16:10
I should have also asked if the fridge runs on 12 volts whilst you are driving.
FollowupID: 723272
Follow Up By: Peter B5 - Saturday, Apr 09, 2011 at 16:11
Hi Notso
- no the lights don't work
FollowupID: 723273
Follow Up By: Peter B5 - Saturday, Apr 09, 2011 at 16:16
The fridge is three way & we have run it on DC when travelling & it works
FollowupID: 723274
Follow Up By: Notso - Saturday, Apr 09, 2011 at 16:17
What I'd look at getting done when you have the second battery done is add an anderson plug to the back of the tow vehicle then have em put an anderson plug on the van with decent sized wires to run your 12 volts in the van. I don't know how it's wired at the moment so you'd need advice from an auto lec, or your caravan dealer.
Most van wiring is borderline when you try to run the fridge on 12 volts and a 7 pin plug is right at the limit with the amount of amps a fridge on 12 volt draws. That's why most of us vanners use the anderson plugs as a separate power supply independant of the 7 pin.
FollowupID: 723275
Follow Up By: Peter B5 - Saturday, Apr 09, 2011 at 16:22
Thanks for your advice.... I note also that the solarforce has a DC + & DC - ports at the back of the unit. Perhaps that is where I could run the wiring to the Anderson plug to attach to the 4wd
FollowupID: 723278
Follow Up By: Notso - Saturday, Apr 09, 2011 at 16:42
It sounds like that, just check what amps it needs as a supply and make sure the wires from the vehcle battery to the plug and the Van wiring is big enough to supply the necessary amps. I have something similar but mine is fairly old and only needs 20 amps, I know some of the later ones need a better supply.
FollowupID: 723280
Follow Up By: Peter B5 - Saturday, Apr 09, 2011 at 16:48
The solarforce unit is designed to supply 28 amps continuous current at 13.8 Vdc
FollowupID: 723281
Follow Up By: Notso - Saturday, Apr 09, 2011 at 16:55
Yep, so with any losses in the system you'll need supply wiring a bit more than that so have chat to someone who can do the calculation s for you. You may get someone on here reply later on.
FollowupID: 723284
Follow Up By: Peter B5 - Saturday, Apr 09, 2011 at 16:59
cheers for your help
FollowupID: 723286
Follow Up By: oldtrack123 - Saturday, Apr 09, 2011 at 17:01
Did you receive a manual for it?
If it's the model I think it is ,you have a combined regulated power supply & multi stage charger suitable for all types of batteries
It does need to be programed & wired correctly, suggest you do not attempt anything with out a manual & understanding what it says
FollowupID: 723287
Follow Up By: Peter B5 - Saturday, Apr 09, 2011 at 17:05
No Manual just a couple of pages. Its a SFPS-1228 model . It has an input voltage of either 115 or 230V its factory set to 230.
FollowupID: 723288
Follow Up By: oldtrack123 - Saturday, Apr 09, 2011 at 17:31
Hi B5
Ok, that model is purely a regulated power supply
Will not charge batteries even on mains supply
Since ,@ this stage you are only looking for overnight use of battery while travelling & driving each day
I would suggest you feed battery from tug battery
Ignition controlled relay to avoid possible flattening of crank battery
Heavy cables battery to battery & Anderson plugs for connection between.
it would be best if you had a selector switch rather than connect battery to the solar force output .
FollowupID: 723291
Follow Up By: Peter B5 - Saturday, Apr 09, 2011 at 17:47
Cheers for that. Will speak with Auto Elec soon, agree selector switch sounds the better option.
FollowupID: 723294
