Good Quality Tyre Levers?
Submitted: Sunday, Apr 10, 2011 at 16:23
Axle
Is there a pacific Brand that stands alone?, and best place to purchase?
Thanks.
Cheers Axle
Reply By: Diesel 'n Dust - Sunday, Apr 10, 2011 at 16:31
Axle
I use TyrePliers for work and find them the best at removing the split rims for repairs
http://www.tyrepliers.com.au/
Matthew
450848
Follow Up By: Member - Bucky - Monday, Apr 11, 2011 at 03:37
That is the go Matthew
Love my Tyre Plyers
Stronng As !
723444
Reply By: MEMBER - Darian, SA - Sunday, Apr 10, 2011 at 16:44
I bought a pair of levers from a local Mumme agent, mainly because they are made in SA (it says so on their site - is it true ? :-o) - hopeful support for local industry. Can't report on their field use yet - have done one test tyre change only - at a glance though, they seem extremely robust - I'd hate to try and bend one -
mine will next be used when I'm out of spares out in the bush (unlikely)...... :-o).
Mumme Forged Products
450849
Follow Up By: Member - Phil G (SA) - Sunday, Apr 10, 2011 at 21:00
I'm with Darian, Mumme brand levers are great.
723435
Reply By: Member - Stephen L (Clare SA) - Sunday, Apr 10, 2011 at 17:20
Hi Axle
If you are serious about changing tyres yourself, then a good quality set of tyre leavers is what you need and I have a set of Dowidat 24" levers and they have never let me down. I have seen cheap Asian made levers break, so be warned, quality is what you need.
To break the bead, I use TyrePliers and then the levers come into action along with a good heavy rubber mallet.
450852
Follow Up By: Hairy (WA) - Sunday, Apr 10, 2011 at 18:26
I second that........ 24" Dowidat are the go
723409
Follow Up By: Axle - Sunday, Apr 10, 2011 at 18:35
Ok,!!.....So where do i get Em!!?
Cheers Axle.
723410
Follow Up By: Member - David G (WA) - Sunday, Apr 10, 2011 at 19:04
If you are in WA try Atom Supply McDowell st
Welshpool
Cheers Dave
723413
Follow Up By: Member - ken b (QLD) - Monday, Apr 11, 2011 at 14:23
hi. i am with you stephen. i have used dowidat for 40years,and they are first class. the 2x24" pair that i have,has changed and repaired a lot of tyres. i bought them at repco. regards ken
723471
Follow Up By: Hairy (WA) - Monday, Apr 11, 2011 at 20:37
A tyre
shop!!!!????
723524
Reply By: blue one - Sunday, Apr 10, 2011 at 17:56
Let me know how you go Axle as I need a couple also.
450855
Reply By: Hairs & Fysh - Sunday, Apr 10, 2011 at 19:58
Hi Axle,
Got a good set of levers as
well as Bead Breaker, using the standard 80 series bottle jack
Image Could Not Be Found
It's slightly different, but used the same as this.
Simple Bead Breaker
450871
Follow Up By: Michael ( Moss Vale NSW) - Sunday, Apr 10, 2011 at 22:27
I made and used a similar gizmo on the Patrol and it works perfectly every time.. Michael
723440
Follow Up By: Ozrover - Monday, Apr 11, 2011 at 10:39
H & F,
I use a high lift jack or a R&R beadbreaker to break the beads when away from home, but you've got me intrigued, how does that work with the 80 series jack?
723453
Follow Up By: Ozrover - Monday, Apr 11, 2011 at 10:43
OOPS! Should have followed the link first!
That is similar as to how I use the high lift jack!
723454
Follow Up By: Hairs & Fysh - Monday, Apr 11, 2011 at 19:02
Yeah, similar to using a Highlift.
I've used my Highlift as one as
723496
Follow Up By: Member - Phil G (SA) - Monday, Apr 11, 2011 at 19:45
I wrote the article, and I also use a high-lift jack!!!
723509
Follow Up By: Hairs & Fysh - Monday, Apr 11, 2011 at 19:56
A great little tool to carry, easy to use.
Phil,
Thanks for sharing.
723512
Reply By: Member - Ed C (QLD) - Sunday, Apr 10, 2011 at 20:05
Apart from a couple of rusty old Dowidats, which I've had for longer than I can remember, I also have a set of 4
same as this set here
Which, IIRC, I bought from Bursons a few years ago... Had a good look at 'em before I decided "these look all right", and I've changed more than a few tyres since I've had 'em... I reckon they're the "duck's nuts" ;-)
Value-for-money, they would be hard to beat, IMO
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
450873
Follow Up By: Member - Roger T (SA) - Sunday, Apr 10, 2011 at 20:25
a good, large truck tire dealer,preferably a country one, they are the people to talk to. if they dont carry them they will get some in. i have 2 German ones and they flex very little i dont think braking them would be.talk to people who use em.
723429
Reply By: Member Al (Sunshine Coast) - Monday, Apr 11, 2011 at 12:23
Rather than buy and carry beadbreakers I made this gadget:
It attaches to either my vehicle hydraulic jack or to my hi-lift jack:
Pops the bead off with less tyre deformation than the jack alone.
Of course it still needs levers for tyre removal.
And re-seating the bead is the next challenge.
450916
Follow Up By: Hairs & Fysh - Monday, Apr 11, 2011 at 19:06
What a nifty gadget.
Cheers Al,
723501
