Removing a Lift Kit from a 100 Series Landcruiser
Submitted: Monday, Apr 18, 2011 at 19:59
ThreadID: 85723 Views:7340 Replies:5 FollowUps:14
Folks,
I'm looking at buying a Landcruiser which has a 2" lift kit installed. Can anyone tell me what is involved in removing the lift kit returning it to normal height.
Reply By: snoopyone - Monday, Apr 18, 2011 at 20:04
If it has Polyairs in it will be a bit of a problem as you have to remove the bump stops and drill the locating nut out of the top to fit them.
You will therefore have to fit a shorter pair.
Depends on if its a body lift or a suspension lift I guess.
AnswerID: 451709
Follow Up By: TheMightyMoose - Tuesday, Apr 19, 2011 at 18:27
The bump stops can be easily refitted even if you have had polyairs in the past. Has been done on ours.
FollowupID: 724424
Follow Up By: snoopyone - Tuesday, Apr 19, 2011 at 18:49
Well would be hard in most as the fitting instruction say to have a 45mm hole in the top where the nut is so that is usually drilled out with a hole saw to get the required clearance for the tube to the valve.
Was on mine and my bosses Sahara so would be pretty hard to put back.
Perhaps you could enlighten us how to refit them if Polyair instructions were followed correctly.
FollowupID: 724426
Follow Up By: TheMightyMoose - Wednesday, Apr 20, 2011 at 13:23
The shop that replaced the springs did it at no charge so couldn't have been too hard. They said something about a couple of large washers if I recall correctly. Anyway the bump stops are present now and weren't when I bought it (with the large holes and no air bags!)
FollowupID: 724501
Reply By: Member - John B2 (VIC) - Monday, Apr 18, 2011 at 20:06
Hi Mapesy,
Is it IFS or rigid front end??
AnswerID: 451710
Follow Up By: Mapesy (QLD) - Monday, Apr 18, 2011 at 20:20
IFS I believe. It's a HJD100R GLX model
FollowupID: 724329
Follow Up By: Roachie.kadina.sa.au - Monday, Apr 18, 2011 at 21:12
I've just had mine raised today. I was in the workshop most of the day watching the blokes swing the spanners.
On the rear, it was a simple matter of replacing the springs and shocks with longer items.
The front was a bit (lot) more complicated. They had to add new, heavier torsion bars, add a gearbox drop adaptor/spacer, weld strengtheners onto the A arms and replace the shockers.
I achieved an approximate 4" lift at the front and 1.5" lift at the rear. Having said that, it needs to be remembered that my cruiser is a 2003 model which I just bought, with 244,000klm on the clock and suspension was original, so it was not as high as it would have been when new. Consequently, the actual lift (from a "new" vehicle), is probably only around 2".
So, to remove that, it would just be a case of replacing the 4 shockers (if necessary), replacing the rear springs with shorter ones and provided there was no spacer used on the front diff, simply either replace the torsion bars with factory ones....or....if the lift was gained by simply winding up the original torsion bars (some bodgey blokes apparently do this!!!), then just wind the torsion bars back down again.
Not sure why you'd want to do all that though?????
Roachie
FollowupID: 724339
Follow Up By: Roachie.kadina.sa.au - Monday, Apr 18, 2011 at 21:13
EDIT: I said "gearbox" spacer...... Wrong!!! I meant to say "front diff spacer"... sorry.
FollowupID: 724340
Follow Up By: Member - Captain (WA) - Tuesday, Apr 19, 2011 at 01:00
This Roachie must be an imposter!!! The one I know would never put his butt in a Toyota, never mind owning one - what is the world coming to (said as I watch 2011-100 days of disaster!).
Gee's , I didn't realise hell has finally frozen over.
Cheers mate
Captain
FollowupID: 724356
Follow Up By: Roachie.kadina.sa.au - Tuesday, Apr 19, 2011 at 18:17
G'day Captain,
Yes mate....I've gone soft (around the middle and in the head)!!!!! hahaha
FollowupID: 724423
Follow Up By: Member - Ruth D (QLD) - Tuesday, Apr 19, 2011 at 19:32
Hey Roachie, 'member that time I peered around the back of the tilt tray recovery truck (in Birdsville) and realised it was your vehicle on the top of the tray -did I say anything to you then about getting a Toyota?
No I was too nice - I even gave you time to get home and tell everyone on EO before I got on and dobbed you.
Well well, a Toyota - that place must have frozen over.
Ha ha.
FollowupID: 724435
Follow Up By: Roachie.kadina.sa.au - Tuesday, Apr 19, 2011 at 20:29
G'day Ruth.....
You are too much of a lady to have taken the pisz out of me when I suffered an untimely misfortune!!! hahaha
Yes, I'm copping a real ribbing from both sides of the track now!!! The Nissan camp reckon I'm a traitor and the Cruiser mob reckon I have finally grown half a brain!!! SIGH.... ;-)
I seem to recall the other vehicle on the flat top was a 100 series owned by a member on here....it had a blown drive train.
Oh well, we will just have to see how this machine goes. I swore I'd never buy an auto or a Toyota......now I have both!!! hahaha
Roachie
FollowupID: 724441
Follow Up By: Member - Ruth D (QLD) - Tuesday, Apr 19, 2011 at 20:51
Oh that's right - I even remember his name.........
FollowupID: 724447
Reply By: Gronk - Tuesday, Apr 19, 2011 at 12:13
Wait till you get it and drive it around for a while and you might like the way it drives ?
Even if you don't want/intend to take it off road, the cost may outweigh the disadvantages of leaving the lift in ??
AnswerID: 451779
Follow Up By: Muddy.au - Tuesday, Apr 19, 2011 at 20:32
I agree with Gronk, try it out first. All IFS need to lifted in the front to level them out then it depends what kit has been installed.
FollowupID: 724443
Follow Up By: Richard W (NSW) - Wednesday, Apr 20, 2011 at 04:20
Another agreement here.
My 2" lift improved the ride no end both on and off road.
IMHO much better than the standard stuff which I found a bit soggy.
FollowupID: 724468
Reply By: snoopyone - Tuesday, Apr 19, 2011 at 13:33
I have a set of standard rear coil springs if you need them In Qld as well.
AnswerID: 451784
Reply By: Kimba10 - Wednesday, Apr 20, 2011 at 00:10
May I ask why you want to remove it ?? If decent quality it probably rides and sits better/level then the ome stuff would have..............
AnswerID: 451837
Follow Up By: Mapesy (QLD) - Wednesday, Apr 20, 2011 at 15:47
It may well be right to leave the lift as it is however it does look high (swmbo would almost need a stepladder to get in it). I guess, if I decide to but it, I will trial it first with the lift. If no good etc. I'll then look at lowering it.
FollowupID: 724508
