Caravan Water Tanks
Submitted: Wednesday, Apr 20, 2011 at 07:58
Clint & Chell
Hi fellow wanderers
Can anyone advise me of what maintenance is involved in caravan
water tanks to ensure that the quality of the
water is safe. Also how often one should undertake this maintenance. As we have spent a fair bit of time at caravans parks over the last few months the
water in the
water tanks has only been used very infrequently.
Happy travels.
Chell
Reply By: Member - Boo Boo (NSW) - Wednesday, Apr 20, 2011 at 08:27
G'day Chell
About every 6 months I drain the
tank at home then refill and put a bottle of miltons (the stuff you wash baby bottles in) in the
tank and take the van for a 10 minute drive to shake it up a bit then leave it sit for 30 minutes then drain, make sure you drain it all, then give it a rinse with the hose and refill.
Go by the directions, if you put to much in the
water can taste a bit like chlorine.
451854
Reply By: Roughasguts - Wednesday, Apr 20, 2011 at 09:34
So far me tanks been used rarely in 3 years but the
water is still okay no bad taste or odour.
So I guess it depends on the quality of the
water you have in there to start with.
But yes
Milton if the
tank does go bad would be the go.
451859
Reply By: Member - barry F (NSW) - Wednesday, Apr 20, 2011 at 11:05
Hi Chell, we periodically pull up half our or so after leaving a van
park & open the drain cocks & then let them both drain as as we mosey along. My theory is that the movement of the van will suspend any foreign material in the
tank & hopefully it will drain out as
We have never put any chemical in our tanks, but if we were to I would agree with
Milton. Cheers & happy travelling
451868
Follow Up By: Polaris - Wednesday, Apr 20, 2011 at 15:41
What a waste of good
water!
724506
Reply By: Member - colin J (VIC) - Wednesday, Apr 20, 2011 at 13:12
Hi Chell,
I have owned vans for the past 30 years continuously and have never had to flush out the tanks. Sometimes the van has not been used for 6 months at a time, but the
water is still fresh. If you put clean
water in why does it go off, farmers and rural people use
water that has been sitting in rain
water tanks for far longer periods and that is still ok. As it is dark and sealed it is virtually impossible for anything to grow or cause a problem.
When you get back from a trip you can fill the tanks right up and that will also cut down on the air space as
well. Put only fresh
water in and you should have no problems. Why waste perfectly good
water by draining your tanks, that has got me puzzled.
Now if you had a problem of some sort then that is another question.
Regards from Col.
451875
Follow Up By: Member - barry F (NSW) - Wednesday, Apr 20, 2011 at 18:45
Good point Colin, I had not looked at it that way & will do likewise in the future provided my last point of refill was not "suss" in anyway which would be very unlikely. Hoo Roo & happy travelling
724527
Reply By: Lucko - Wednesday, Apr 20, 2011 at 14:34
Maybe I'm anal but, when we get home I drain both tanks, about 1/4 cup household bleach in each
tank and fill with
water. Pump through the system, through taps until you can smell the chlorine and then shut down. Drain and flush once just before next trip. I've been doing this for quite a few years, the reason, it keeps the
water sweet particularly since I have a fair bit of clear plastic connecting pipes in the system. Algae can and will grow in clear pipes where the sunlight can get to them. Hope this helps
Mark
451882
Follow Up By: Polaris - Wednesday, Apr 20, 2011 at 15:44
You can stop the algae growth in your system by simply lagging your clear plastic with black electrical loom tube - or replace the clear with black poly.
Once the source of the algae is eliminated then there will be no need to drain and waste good
water.
724507
Follow Up By: Lucko - Wednesday, Apr 20, 2011 at 16:06
You're right, replacing pipework is on my 'to do' list when I get aroundtuit.
No
water wasted at our place old son,
water on storage, naturally dechlorinates. All
water drained feeds the vegie garden.
Mark
724509
Follow Up By: Member -Dodger - Wednesday, Apr 20, 2011 at 16:46
To save a lot of work if you have clear pipework.
Wipe down with a metho soaked cloth then use a black spray paint to cover the claer plastic. It will take several days to completely dry but even if it is still tacky when you drive some dust may adhere but that also helps.
This is for the underneath van bits only, in the van use algging as suggested.
724513
Follow Up By: Polaris - Wednesday, Apr 20, 2011 at 17:40
Mark - good to see that you are being responsible and putting your
tank water to good use - unlike some who have posted here that they let it drain along the road.
Good one fella!
724520
Follow Up By: Member - barry F (NSW) - Wednesday, Apr 20, 2011 at 17:56
OK OK OK alright already Polaris. Nuff said You can climb down off the fence now & clean your bazooka in readiness for the next pot shot. LOL & happy watering. Cheers
724523
Follow Up By: Lucko - Thursday, Apr 21, 2011 at 12:12
Thanks Dodger, I'm going the black plastic path, but as I said when I get tuit.
Mark
724606
Reply By: Clint & Chell - Wednesday, Apr 20, 2011 at 20:39
Thanks everyone for you informative reply's I am happy to just use the
water when we need it and only empty if there is a problem. We do have a
water filter both externally & internally so I think we should be pretty right.
Happy & safe travels.
Chell
451928
Reply By: Motherhen - Wednesday, Apr 20, 2011 at 23:15
Hi Chell
While there are two viewpoints here, i do not drain the tanks. Pure
water does not go off. The
water coming from bores and artesian sources may have been accumulating underground for tens of thousands of years. Across the nation, many people have been relying on
water stored in tanks which may not be completely emptied year after year, and they are not as sealed from sunlight and contamination as caravan tanks are.
Water in a caravan or camper
tank is not exposed to sunlight so will not grow algae and will be safe even if left for years.
If you drain the tanks, remnant dissolved salts or calcium may crystallise and could cause blockages in pipes, taps or pumps.
For those who feel there may be a need to cleanse the tanks, add a little household bleach to some
water (or swimming pool chlorine if you have it) and swill it around in the tanks before emptying and flushing with fresh
water ready for refilling.
This article
Water and linked article on collecting
water (including filling hose types and filters) has more.
451952
