PVC Pipe Tanks
Hi all,
Am about to put a few 100mm pvc pipes under the tray of the hilux for some extra water. Just wondering if anyone had some plans or pictures of what they have done to give me ideas. how would you link and fill them. Thanks for any answers in advance.
Reply By: disco driver - Friday, Apr 22, 2011 at 23:30
Dave,
Have you done the maths on using PVC pipe as far as water capacity is concerned?
It works out at about 7.8 litres per metre of pipe length.
I considered using PVC on an earlier vehicle (tray back Landrover) of mine but found that I could fit a caravan water tank of about 55-60 litre capacity under the tray into the same space. The tank was only 150mm deep and fitted between the tray crossmembers directly behind the cab.
The filler and outlet system the same fittings as used in a caravan.
I found it quite easy to mount onto the vehicle from underneath but it was a bit awkward working on my back to do it.
Google 'caravan water tanks ' to find out the sizes available
Hope this helps.
Disco
aka Tony
AnswerID: 452106
Reply By: Farmboywa - Friday, Apr 22, 2011 at 23:42
G'day Dave S, I made a 2.4m x 150mm tank using sewer grade pvc tube, sealing the ends with glued on threaded fittings for screw on end caps. Short piece of 20mm pvc tube with glued on threaded end fittings for attaching to water tank and screwing on cap. Suction hose from van hand pump draws water from thr tank and filling is by using a funnel. It holds about 50L. Your 2.4m x 100mm tanks would hold about 2/3 this amount or about 34L. It cost me about $100.00 in materials for the 50L tank. I would rather have been able to use plastic jerry cans but the pvc tank was necessary to fit on the floor of a 8x5 trailer along the side of the slide on. Don't skimp on materials, your tanks are in for a rough ride.
AnswerID: 452107
Follow Up By: Lucko - Saturday, Apr 23, 2011 at 13:32
This may be daft, but I've read somewhere that the blue PVC adhesive can poison drinking water once the temperature gets above about 40 deg. Perhaps a furphy, but perhaps worth asking some questions.
Mark
FollowupID: 724818
Follow Up By: Whirlwinder - Saturday, Apr 23, 2011 at 13:59
Yes Lucko, I have read the same thing. I think it was "toxic" rather than poison though.
FollowupID: 724819
Follow Up By: Lucko - Saturday, Apr 23, 2011 at 14:42
Either way, if it's true, I would not like to store my drinking water that way, shower water, sure but not drinking water. Again, the claim needs to be proven I guess.
Mark
FollowupID: 724820
Follow Up By: snapper49 - Saturday, Apr 23, 2011 at 18:25
My understanding is that sewer grade is meant to be buried and not exposed to sunlight as its not UV resistant
FollowupID: 724825
Follow Up By: rags - Saturday, Apr 23, 2011 at 21:03
There is only 1 grade of pipe available now days at most suppliers,this being DWV,which is suitable for uv exposure ,note that this pipe is a sandwich constructed pipe with an inner and outer layer of pvc with a centre core of recycled material and not as good/strong as pvc that was once available.Sewer pipe now is only available as SH grade which is only used in Supply mains construction and would be ordered on request.
Also be aware that any pvc material may contain lead in its makeup.
hope this asists
FollowupID: 724828
Follow Up By: Farmboywa - Saturday, Apr 23, 2011 at 22:43
G'day Dave S, some interesting information coming out of followups has led me to check PIPE MAKERS website. PVC pipe not recommended for storage of potable water. See Safety Data Sheet tab.
FollowupID: 724829
Follow Up By: bibtracker - Saturday, Apr 23, 2011 at 23:30
Would have thought that a few jerries would be :
Cheaper
Easier to store
Safer (given concerns about PVC).
Just a thought.
Cheers, Tony
FollowupID: 724831
Follow Up By: dags666 - Sunday, Apr 24, 2011 at 05:16
if you are woried about the glue [blue glue ] use pressure glue, green in colour it gets used on water preesure pipe
DAGS
FollowupID: 724836
Follow Up By: River Swaggie - Sunday, Apr 24, 2011 at 16:01
Coleman have 20litre collapsible water containers and i use them all the time...
FollowupID: 724856
