Towing With A Landrover Discovery
Submitted: Monday, Apr 25, 2011 at 07:57
ThreadID: 85846 Views:3301 Replies:6 FollowUps:3
Anyone here tow a big van (2.7 tonnes loaded) with an older Landrover Discovery
TD?
They have the towing capacity, but do they have enough power?
Amongst a number of reasons for asking this question, I will need a temporary
tow vehicle for up to twelve months, while waiting for a new vehicle.
They are quite inexpensive (from $7k and up) and readily available, so could suit
me for my short term purposes.
Robert
Reply By: Who was that again? (Vic) - Monday, Apr 25, 2011 at 09:28
A friend towed a 2.2T loaded Kimberley Karavan with one, and on one trip cut the plugs off so he never would be tempted to again. He went home and bought a Landcruiser 100, one of the last to come into Australia.
AnswerID: 452236
Reply By: Madfisher - Monday, Apr 25, 2011 at 09:33
Lack of low down torque (try to start off on a hill) would be biggest issue. If its only for 12 months a 4.5 80 series cruiser or similar size pAtrol motor in petrol would be a safer bet. If that little 2.5td blowes it will cost you more then $7000 to fix. The big normally aspirated 6cylinder diesels while lacking in top end have masses of low down torque for getting underway.
But really you need to test drive one and see if it suits you.
Cheers Pete
AnswerID: 452238
Follow Up By: Axle - Monday, Apr 25, 2011 at 18:48
The Trouble is mate, Would he be able to afford the hire of a fuel ltanker to follow him around ?....LOL.
Cheers Axle
FollowupID: 724957
Reply By: Member - Mark E (VIC) - Monday, Apr 25, 2011 at 09:49
Robert,
I had a 2.5 turbo Disco a few years ago.
Short answer to the question is ..."no". They simply do not have sufficient power to tow a heavy load.
The heaviest load I ever towed was a tandem trailer full of bricks. I have no idea how heavy it was, but even the slightest hill had me in low range to start off and the clutch didn't like the whole experience.
Petrol Landcruiser or Patrol would suit your application but the fuel usage would hurt IMO.
Mark
AnswerID: 452240
Reply By: Member - Terry W (ACT) - Monday, Apr 25, 2011 at 10:01
Robert,
While many think of power and braking as the major determinants of towing capacity, in some cases stability is the major factor in determining what is safe to tow. I regularly towed 2.7 tonnes with a Disco 2, but it was marginal at best from a stability point of view. I replaced it with an LC200, and still haven't quite come to terms with how much more stable this rig is compared with the Disco. I am not knocking Disco's: I loved mine and was sorry to see it go, but it has neither the weight nor the wheelbase to tow heavy (over 2.5 tonnes) vans with the degree of safety that I want for me and my family. While the D2 was a very different vehicle from the Disco you are considering, it had a similar weight and identical wheelbase, so I believe that stability, or the lack thereof, would almost certainly be a significant issue for you too. Hope this helps.
Terry
AnswerID: 452242
Reply By: mullyman - Monday, Apr 25, 2011 at 18:04
The RAA chap down at Salt Creek in S.A. has a 2.5 turbo Defender and a 4.2 turbo Nissan. He uses the Defender for towing. Insists that the Nissan is next to useless.
AnswerID: 452282
Follow Up By: Madfisher - Monday, Apr 25, 2011 at 19:44
Well he must have an exceptional defender or a dud td Patrol.
Cheers Pete
FollowupID: 724963
Reply By: mullyman - Monday, Apr 25, 2011 at 19:49
It's all about real torque,not internet talk.
AnswerID: 452291
Follow Up By: Madfisher - Monday, Apr 25, 2011 at 21:04
Exactly
FollowupID: 724976
