Friday, Apr 29, 2011 at 17:50
Mazcan
Your dead right about the 38,982psi and he did "clearly say it scanned at 38,982psi" and I am even more sure that I did not contradict those figures in any way what so ever.
I am even more sure that Russell said he wished to get the aforementioned pressure down to 3,000psi:
Just to get some clarity in this tread I will copy and paste Russells exact words:
"I have just replaced my diesel injection pump and still won't start ! I have put it on the scan tool and tells me that it has 38982 psi it should read around (3000) at the
fuel rail wether the sensor is plugged in or not"
Now I read that as Russell stating he wishes to reduce the current pressure of 38982psi down to 3000psi.
I was merely attempting to point out to Russell that later model vehicles like his CRD run a RAIL pressure at around 27,000psi, and therefore his attempt to lower his CRD to 3,000psi would be aiming for to low a pressure.
Then again I could have "mis-read" Russell's figures as you say and if that is so, I apologize most humbly to Russell for misreading his figures and promise never to do so again.
DD
725443
