100 series central locking kit
Submitted: Friday, May 06, 2011 at 06:39
ThreadID: 86101 Views:5264 Replies:5 FollowUps:4
I recently purchased a "universal" central locking kit for my 100 series Standard Cruiser, only to find that the cabling system in the 100 did not allow for the kit to be fitted. The kit requires a steel rod system. Has anyone managed to modify such a kit to fit a 100 series, or know of a kit that would work ?
Reply By: Member - Trouper (NSW) - Friday, May 06, 2011 at 14:11
What do you mean "the 100 did not allow for the kit to be fitted??
I fitted one from Jaycar. You need to run your own cabling which comes with the kit and connect it to a permanent power supply maybe directly off the battery then remove the door trim and connect the Rod and other things so that when ativated the solenod supplied pulls in or pushes up the snipper button. It is a bit fiddly but once you have done the first door the rest will be easier.
regards.....................jeff
AnswerID: 453447
Follow Up By: Stevelongford - Friday, May 06, 2011 at 15:07
Thanks Jeff. When I refer to cabling, I mean the cable that opens and shuts the locking mechanism, not the electric wiring for the kit. Some vehicles have a steel rod attached to the lock but the 100 series cruiser has a cable which is encased in a plastic outer case - like a brake cable on a bike. This means that the rod that comes with the kit can't be attached to the actual cable that operates the lock. There are small metal clips that come with the kit that are designed to attach the rod to the locking mechanism, but this can't be done because of the outer protective layer over the cable. Hope this makes sense ?
FollowupID: 726222
Reply By: Member - Trouper (NSW) - Friday, May 06, 2011 at 19:08
Yeah I get your drift now. Sorry mate cant help
jeff
AnswerID: 453473
Reply By: Member - Toyocrusa (NSW) - Friday, May 06, 2011 at 20:53
G'day Steve. I wonder if you might get some one on lcool that knows. There usually is if it's not in the search results. You may have to join if not already but it's free. Bob.
AnswerID: 453484
Reply By: Steve D1 - Saturday, May 07, 2011 at 12:55
Why not just buy the toyota accessory kit for around $140.
Much easier
Steve
AnswerID: 453523
Follow Up By: Stevelongford - Sunday, May 08, 2011 at 07:57
Thanks Steve. Got a quote for $265 from a mob called Cyclops. Is the Toyota accessort kit a genuine item available from a Toyota dealer ?
Steve
FollowupID: 726426
Follow Up By: Steve D1 - Sunday, May 08, 2011 at 08:47
Yes t is
Give them a call
Steve
FollowupID: 726437
Reply By: pval - Saturday, May 07, 2011 at 18:10
Hi,Search Rapid Electronics online store,they have a central locking adaptor kit you can use $50 for set of 4 and some photos of them in Landcruiser 100 series.
Paul
AnswerID: 453545
Follow Up By: Stevelongford - Monday, May 09, 2011 at 19:57
Problem solved ! Thank you to everyone for their advice. I have now bought the adaptor kit recommended by Paul !
FollowupID: 726603
