Sunday History Photo / Qld
Submitted: Sunday, May 08, 2011 at 04:19
ThreadID: 86130 Views:6817 Replies:3 FollowUps:2
The business Southern Cross was started in 1871 by a newly arrived English immigrant - George Griffiths. Originally operating as an ironmonger and doing mechanical repairs in Toowoomba, Queensland, he was soon joined by his engineering graduate brother, John. At or about 1874 Giffiths Bros. & Co. purchased more land in Toowoomba and started The Toowoomba Foundry.
Over the years Southern Cross has manafactured a wide range of equipment catering to the needs of pioneering farmers. It was realised early on that the most basic need in the successfull development of rural Australia was a constant, reliable supply of water for farming and associated comunities. In response to this the company built some of the earliest windmills in Australia. These were The Simplex, The Simplex Economy and The Little Wonder.
In 1903 the company built a series of windmills under the trade name " Southern Cross". These were an immediate success. Other watering and bore equipment produced soon after was also sold sucessfully as "Southern Cross" and so the name was adopted by the company. By 1913 Southern Cross employed over 400 people in 9 acres of factory property in Toowoomba.
They were also involved in producing dredging equipment used in the initial dredging of the Brisbane River. Rolling stock, railway sleepers and steam engines were also manafactured by the company. Their agricultural equipment included - wool presses, dairy equipment, various pumps, compressors, lighting plants, windmills, well drilling equipment, steam engines, IC engines for petrol, kero and diesel and all equipment associated with these machines. During WW2 they supplied munitions, engines, pumps and compressors for the British in North Africa, the Americans in the east and to the Australian Navy and Army. They have also extensively supplied the mining industry in Australia with diesel engines, compressors, gensets, winches, ore crushers and of course pumps.
(The windmills became known as the "Griffiths" Mills. In 1903 the Toowoomba factory sold its first commercial windmill under the trade name the "Southern Cross". The Southern Cross windmills were design by Bert Giffiths and it was simple, robust and relatively cheap. The windmills were 8ft high and made from galvanised steel. The Southern Cross became the best known and sold windmill in Australian history and is now an Australian icon.)
In 1933 they started manafacturing a range of medium speed heavy duty diesel engines. They were simple and effective and sold well with power outputs ranging from the small single cylinder YB of 3 horsepower, to the 42 horsepower 4 cylinder YGB. Prices in the 1941 catalogue range from 73 pounds for the YB to 470 pounds for the YGB. They used wet liners, shell big end bearings, standard CAV or Pyrox injection pumps and could be cold started without pre-heating.
Image Could Not Be Found
Note: The first engine I found had the plate on it, it has the Gov't arrow stamped on the plate, made in 1942 it was probably used by the Military , further research into this is ongoing.
In 1947 the "Y" range was upgraded with the "B" range. The (now 4 hp) YB however was continued and sold well with the newer BDC, BEC, BFC and the big 4 cylinder BGC 40 horsepower engines. One feature of the "B" range is that they all had the same bore and stroke and most vitall parts including pistons, valves, liners, con rods and bearings were the same on all models. Prices in the "B" range were from the base model YB at 137 pounds to 842 pounds for an electric start BGC of 40 HP.
Aesthetically the "B" range are just big, functional but not generally sought after by collectors. The YB being only 4 HP and relatively small are still popular and can often be seen at shows and rallies. Southern Cross engines peaked in their appearance with the YDB. They are tall, slender, powerfull engines ( 10.8 HP ) that look great if one has room for an engine that size and more difficultly - can find one.
Southern Cross ceased production of diesel engines in 1970 due to their inability to compete with cheaper imports.
Reply By: Nickywoop - Sunday, May 08, 2011 at 05:59
Well done Doug,
Another very interesting Sunday morning history read.
Your research is and writing is an inspiration to all.
Regards Nick
AnswerID: 453585
Follow Up By: Member - Doug T (NT) - Sunday, May 08, 2011 at 06:04
Nick
No , not all is my writing, some is copied , I do the researching in the stories, sometimes I have to write it off files and that takes time, I can't take credit for all text you see,..
FollowupID: 726424
Reply By: Member - DAZA (QLD) - Sunday, May 08, 2011 at 06:21
G/Day Doug
Great thread.
I have been involved with a lot of installations re: Southern Cross Equipment over the years, an it was simple technology, nothing flash but guaranteed to last.
AnswerID: 453586
Follow Up By: RoyHarvey - Sunday, May 08, 2011 at 09:56
Back in the 80's I was working for a company that sourced ventilated front disc castings from Toowoomba foundry.
As I recall they were our one of best suppliers, the castings were always good quality and supplied on schedule.
FollowupID: 726448
Reply By: Member - Rod N (QLD) - Sunday, May 08, 2011 at 11:20
There is quite an extensive display in the Southerncross building at the Highfields Pioneer Village north of Toowoomba.
This is from theToowoomba Chronicle
"The Southern Cross Museum project involves the preservation of 150 historic machines and 250 photographs and documents.
Museum curator Ray Ashford said the project was of national significance which was why it had attracted such strong support.
“Originally, the foundry was called Griffiths and Atherton in 1871, then (in 1873) renamed Griffiths Bros. and Co,” Mr Ashford said.
“Then later after the Southern Cross windmill was designed in 1902 all products made after that were named under Southern Cross.”
The oldest item at the museum is one of the first artefacts made by the Toowoomba Foundry, a plate off a steam engine from 1873.
The museum features one of every type of engine and pump made by the Toowoomba Foundry.
“The project is in its first stage and is ongoing,” Mr Ashford said.
“We wish to extend the building, do more research and then also feature the people who made these items.”
The project has had 30 volunteers on hand to help and their great work will be on show when stage one will be officially opened on June 27 at 10.30am by Senator Claire Moore.
Former and present Toowoomba Foundry and Southern Cross employees and their families have been invited to the official opening.
Entry fee is $10 and includes admission to the Pioneer Village and billy tea.
Former employees are also able to buy a plaque for $50 which will be on show displaying the years they worked at the foundry and what they did. Money raised goes back to the museum.
For more information contact highfieldspioneervillage@hotmail.com or 4696 6309."
AnswerID: 453610
