Dometic 2553 Fridge
Submitted: Tuesday, May 10, 2011 at 12:44
Puttingdave00
I have a relatively new (15 months old) Dometic RM 2553 fridge in my Van, Problem : 2 of the freezer door spring housings have broken and I cannot work out how to fit the new ones with enough tension on
the springs to hold the freezer door closed, would any one out there in the Caravan world be able to help me please. These little pieces of plastic are $35 each which leads me to believe that it may be a fairly common problem with these fridges.
Puttingdave@gmail.com
Reply By: Hairs - Tuesday, May 10, 2011 at 17:39
If they are the same as the rest of the range, it's is a little tricky, but once you get your head around the idea they are easy enough to replace.
Down load a copy of this
This Frig Manual!( It's for a RM360, but should be the same as yousr, Page, 9 Frig 11 & 12
Your have to put the tension (anti clockwise I think) on them before your screw it to the door.
Hope this helps.
Hairs
453866
Follow Up By: Hairs - Tuesday, May 10, 2011 at 17:43
LOL, Fridge , not Frig Manual. And not Yousr, Yours.
I'm having a Joe Cocker
Dohlt. :)
726686
Reply By: Member - Tony S (WA) - Tuesday, May 10, 2011 at 19:41
They are not that fragile. You must be pushing down to hard when the door is down. We don't have any problems with our 2350.
Gently bently does it.
453883
Reply By: Puttingdave00 - Tuesday, May 10, 2011 at 20:13
Thanks guys for your replys, after posting this
forum I emailed Dometic and within 1 hour I had a set of instructions on how to fit them, again I suspect it may be a fairly common problem, If anyone would like a copy just email me.
453890
