Laptop internet connection
Submitted: Wednesday, May 11, 2011 at 14:01
ThreadID: 86210 Views:3519 Replies:12 FollowUps:16
I am planning to use a Toshiba notebook on our travels throughout Australia. I would like to hear from others as to what typr of internet connections and plans work the best away from cities. I am with Telstra at the moment
Reply By: Member - Rod N (QLD) - Wednesday, May 11, 2011 at 14:14
I have a Telstra NextG Home Network Gateway, external antenna, 3Gig/month plan. Works well for me. NextG is the only network that give a reasonable coverage, but obviously not the whole landmass of Aus.
AnswerID: 453941
Reply By: snoopyone - Wednesday, May 11, 2011 at 14:15
read thread 86126
Get a Maxon BP-3 and it will work anywhere there is phone reception.
They are cheap on Ebay Only thing is they mostly work on 240 volt.
Otherwise you can get a data pack on your phone and use that as a modem
AnswerID: 453942
Follow Up By: Member - John and Val - Wednesday, May 11, 2011 at 14:41
We have a Next G mobile phone that we use as a modem for the laptop and buy data packs as required. Works wherever there is phone reception but away from the main towns and highways reception is very limited. Telstra is the only network that will give adequate coverage in these areas.
Val.
J and V
- Albert Einstein
FollowupID: 726756
Reply By: equinox - Wednesday, May 11, 2011 at 14:25
I hired a Bgan modem last year for 4 weeks.
From memory about $1000 to hire and about the same for usage costs.
Works anywhere in Australia.
AnswerID: 453945
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 15:02
You must have wanted availability badly to pay that for it.
I know its good but definitely not cheap.
FollowupID: 726759
Follow Up By: equinox - Wednesday, May 11, 2011 at 15:32
Not as much as I thought i did :)
FollowupID: 726765
Reply By: Member - Graham N (SA) - Wednesday, May 11, 2011 at 14:26
HI Bonmac,
Just this moment have installed a Bigpond Ultimate Wireless Broadband USB Modem on a Toshiba notebook and yours is the first forum letter I have read what a coincident, working fine so far but haven't been anywhere yet.
Graham
AnswerID: 453946
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 14:31
You would do well to read thread 86126
Will work Ok in town but remember 98% of population live in 8% of the total area of country.
Lots of no access places
I had 3 USB modems, None were much good so I got the Maxon and had no more problems Cost me $26 on Ebay
FollowupID: 726755
Follow Up By: Member - Graham N (SA) - Wednesday, May 11, 2011 at 15:28
Hi snoopyone,
I only brought it to mainly catch up with or send e-mails when in or near towns. I've read thread 86126 is he trying to get a signal further from towns or was he having trouble in towns. I wasn't going to buy a antenna but do I need one?
Graham
FollowupID: 726763
Follow Up By: Graham & Ann - Wednesday, May 11, 2011 at 16:05
We have telstra Next G and External antennae can make huge difference in the outback. Even more so if your using the laptop/modem inside a caravan. We have 6db one (same type) mounted on the car for the phone and one in the van for the modem (or phone) ... If you dont want permanent mounted one the magnetic based model in 6db should work fine.
FollowupID: 726771
Follow Up By: Member - bungarra (WA) - Thursday, May 12, 2011 at 22:51
Graham N (SA)
..if you read my entire postings you would see the issue is stable internet signal in a fringe area...towns with tower nearby servicing them are never an issue with any sort of modem
by the way am back home now hence a good signal....snoopyone has clearly had a similar experience to me and I intend doing exactly what he suggested and get one of the old toasters....in fact I think my daughter has one no longer in use..hopefully she has kept it and then I shall grab it
VKS 1341
FollowupID: 726974
Follow Up By: snoopyone - Saturday, May 14, 2011 at 09:28
I would never use a wireless connection at home as ADSL is faster and more reliable.
Wireless is Ok if you dont have a home phone but hte costs are higher and the connection slower (generally).
My old Maxon is sitting in the drawer till I decide to dispose of it.
FollowupID: 727070
Follow Up By: Member - bungarra (WA) - Saturday, May 14, 2011 at 09:33
we have no choice here on our property.....we had satellite which was better than nothing..
Next G came along and we can get a signal (just)..otherewise we simply would not have internet...still heps better that the satellite
VKS 1341
FollowupID: 727071
Reply By: Member - Boobook - Wednesday, May 11, 2011 at 14:41
Get some kind of Android Phone, Eg a HTC desire on a $49 plan or above on Telstra and on the phone go to
"Menu" > "settings > " Wireless and Networks" > "Portable WiFi Hotspot"
Set it up and then your phone is a wireless router with your own private hot spot that the PC can connect to Telstra's next G wireless phone network.
Very simple to use and the phone can be up high for reception.
AnswerID: 453952
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 15:00
Then let me know whee you are so I can piggyback on it if its an open connection
ROFL
FollowupID: 726758
Follow Up By: Member - Boobook - Wednesday, May 11, 2011 at 17:05
Sorry snoopyone, you'll have to hack into the encrypted WPA2 connection to do that.
I should have mentioned that it is configurable with the same security parameters as a home network, from open to WPA2
FollowupID: 726780
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 17:11
Very good Boobook
Lots dont and dont know though.
I spent a very nice night once at a friends place downloading software on his neighbours open network LOL
FollowupID: 726784
Reply By: DesF - Wednesday, May 11, 2011 at 16:24
Hi. we have a Nokia 6720 Next G ( previously a 6120), and have a $10.00 @ month for 1 gig data pack from Telstra., they just add it to our bill.
we have travelled quite a bit with it and found that it is plenty for normal mail and a bit of internet mainly park info etc , and I just plug it into the laptop and we have instant Net service.
I also use Skype a lot to keep in contact with the family, even using the camera it lasts well,
You can just log on and check you usage at any time, and you can check you usage on your phone also they send a 80% usage notice to your mobile.
Works well, and you can get it turned of when you are home , no charges.
Cheers Des.
AnswerID: 453969
Follow Up By: mikehzz - Wednesday, May 11, 2011 at 23:36
Microsoft just bought Skype.....I'm not feeling good about it for some reason....
FollowupID: 726850
Reply By: Pebble - Wednesday, May 11, 2011 at 18:17
Speaking not as a traveller so much as a person who lives on a rural property, I would say Telstra Next G is certainly your best bet, the only other option to look into would be satellite broadvand but possibly more expensive and more fiddly (as a rural person I'm on satellite because our next G reception is pretty marginal, but I would take next G over satellite if I could).
AnswerID: 453984
Follow Up By: Member - Bill B1 (NSW) - Wednesday, May 11, 2011 at 21:42
G'day,
I have been away for 12 months, through Outback Qld, NT, WA and now doing the peninsulas in SA.
I have a Bigpond modem (the wide white one) and have used it the whole trip. If I have signal on my next G phone, I have the same signal on the modem.
No external aerial, just sticking the modem up against the fly wire on the poptop.
So if no Next G signal then no modem. Some of the signals are low and Skype is voice only, but email and some downloading is OK.
Bill
Bill B
FollowupID: 726838
Follow Up By: Member - Rod N (QLD) - Thursday, May 12, 2011 at 06:25
If you have marginal NextG reception try a yagi antenna. Here is a how to do it Home made Yagi There are commercial versions available as well.
FollowupID: 726857
Follow Up By: Pebble - Thursday, May 12, 2011 at 09:45
Thanks, I've bookmarked the link for future reference.
We purchased some kind of passive antenna that was recommended and it seems to have improved the reception slightly....enough so we can make and receive calls inside the house most of the time. That home made Yagi certainly looks what we would want (or a brought one) if we did decide to give satellite the flick....probably unlikely until I get my hands on a smartphone next time my mobile is due for an upgrade.
FollowupID: 726878
Reply By: Motherhen - Wednesday, May 11, 2011 at 23:23
Hi Bonmac
We too travel with Next G internet (on a Telstra plan), having a small Maxon USB modem which needs no outside power source . We have an antenna which i can put on the caravan roof to boost reception. Next G is usually available up to 20 kms around a town unless terrain is hilly. It is also available along and near to most major highways, particularly those near the east coast.
As we were on the move, we were never much more than three weeks without any signal - enough to conduct banking and business and keep in touch with family. I let family at home know when we were heading into a national park or outback where there was no reception, and told them we would get in touch with them as soon as we reached a town - giving them an indication of days or weeks.
AnswerID: 454029
Reply By: Member - Ian G (NSW) - Wednesday, May 11, 2011 at 23:47
We have had a Telstra Turbo Stick for two years connected to our rooftop NextG antenna on the caravan, via a patch lead with an FME connector directly into the next g antenna from the turbo stick. We have had coverage all over Australia and we are currently between Leonora & Laverton, WA with 4 bars service. The Turbo Stick has a USB slot straight into the side of the laptop and because it works so well bush, I am getting rid of the modem in my house and operating this one full time. There is also a plan for $150 for 365 days with great download speeds that I am currently contemplating. Works well for us at all times. As long as we have 2 bars, we have service.
Ian G
AnswerID: 454033
Reply By: Member - Heather MG NSW - Thursday, May 12, 2011 at 07:04
Hi Bonmac,
The Bigpond Ultimate Mobile Broadband USB is great - compact, has a good signal strength in that it works everywhere my telstra phone does and does not need any antennae. (I am not sure whether an antennae can be connected to it, however if that were possible but it would increase the signal range). It is also very fast when the signal strength is strong.
It is costing me $29.95 for 3 GB per month with rewards, as we have mobile and fixed line also with Telstra on a single bill, and it is my only internet connection because we travel for much of the year.
I recently upgraded from the Maxon BP3 USB which had to be connected to a high gain antennae to get the same reception and I am much happier with the Ultimate.
Don't go with any other company than Telstra/Bigpond as they have by far the best coverage away from the cities. Just dont automatically expect to be able to use it everywhere!
I am surprised by how many places I have a signal and have travelled extensively using mobile wireless now for the last three years in Australia.
Hope this helps you.
Regards Heather
AnswerID: 454040
Reply By: Member - Kiwi_In_Aussie(Wagga) - Thursday, May 12, 2011 at 11:00
Sounds like a simple statement but make sure it has wireless capabilities as well - you will be surprised how many free wifi hotspots are available (cities only of coursse)
I use the local libaray almost daily and of course Maccas has free wifi
enjoy
K.A
AnswerID: 454061
Reply By: Who was that again? (Vic) - Saturday, May 14, 2011 at 07:21
The iPhone 4 with the latest upgrade IOS 4.3 has a nice ability to use it's Hotspot capability for anything wireless, so your laptop, iPod Touch or iPad. Using encryption of course and password. I also have a Bigpond Elite USB dongle with an external antenna which I use through a router on occasions.
Even using the external antenna, the iPhone gets more reliable signal than the wireless modem. More bars and more stable and seems faster. The modem gets slowed when it goes past the limit, and the phone account would cost more. That is just a feature of the accounts!
AnswerID: 454222
