Sunday, May 15, 2011 at 17:02
Faulic said:" None of the small 3 way fridges work over 30c.""
What a load of crap, all those with CORRECTLY installed 3ways must just be imaging they work ok above 30c
I have both an Engel & a correctly installed Dometic 3way, 160amp hrs of batteries,200watts of solar ,& small other power use. Many a time I have had to transfer to the 3way when batteries ran low due bad weather & low slolar charge
2 x 9kg gas bottles lasts about 6 +weeks with cooking included
AS I said before THERE IS NO ONE SIZE FITS ALL
Any one considering a compressor fridge should look very carefully @ their intended modes of camping
Do you have the space for sufficient panels to meet a long term stopover if bad weather sets in?
Or are you prepared to give up & run for
home?
Are you prepared to go for a looong drive to allow the DC to Dc charger charge your aux batteries?
Or are you prepared to let your engine run on fast idle for hrs on end.?
A generator is another option but most are not suitable for direct charging of batteries & need a battery charger!
Not allowed in many NAT pARKS!
Possibly have to carry different fuel!
How close are you to your load limit?
WHAT OTHER DEMANDS ARE YOU GOING TO MAKE ON YOUR SOLAR/ BATTERIES??
LOTS OF FACTORS TO BE CONSIDERED!
If your form of caravanning is mostly caravan parks with only a day or two away from power, then a compressor fridge is the way to go
BUT if camping away from power for extended periods is your intention look very carefully @ ALL THE PROS & CONS
727193
