Toyota tray back 79 series 2006 suspension
Submitted: Monday, May 16, 2011 at 20:57
Diane F
I need advice please. I own a trayback Toyota landcruiser 79 series. It has poly airbags fitted, originally to help carry the slideon. I no longer have the slide on and am looking at buying a 22foot caravan. My question is do I keep the air bags or upgrade the
suspension. Will an upgraded
suspension help also with a more comfortable ride as I am now an older female driver. If you own a vehicle the same as
mine I would appreciate knowing what you have done in this regards. Thank you
Reply By: Member - Anthony W Adelaide - Monday, May 16, 2011 at 21:29
I have a VDJ79 with a 600kg upgrade. I have a few
tools etc on board most of the time, but it is a fairly hard ride without a bit of weight on it. Depending how much tow ball weight you have you may be better off with polyairs or just extended shakles to account for the drop in height, with the standard springs.
The towball weight of a big van may only be 100 to 200kgs? Maybe you have other stuff on the tray to allow for?
Cheers, Wooly
454501
Reply By: Member - bungarra (WA) - Tuesday, May 17, 2011 at 10:57
I have a VJD79 with the
suspension upgrade of 600kg.
I also have BOSS air bags to keep the ride height level when towing our offroad 6.2m 'van
The ride is firm but not harsh when not towing but I am around 3700GVM when not towing....
Basicaly ugrading the
suspension will give a firmer ride but not necessarily more comfortable than the present ride you have...
It is about a trade off between a safe load on a
suspension upgrade designed for that load as against a softer and perhaps less safe ride if you are overloaded or approaching full load pre upgrade
454544
Reply By: Member - Phil G (SA) - Tuesday, May 17, 2011 at 11:23
I have the Boss airbags and ARB 600kg leaf rear
suspension.
I'd leave yours alone and see how it is. If you find its too hard with no weight on board, then reduce your tyre pressures to say 28 psi and see if that's better. With no weight, you don't need higher pressures.
454548
Reply By: get outmore - Tuesday, May 17, 2011 at 15:41
the standard springs really are quite woefull Ive driven plenty of new ones and they dont keep the factory springs for long before replacing them
that generally adds about 2 inches or so of lift because it seems the factory ones come out factory sagged
the first thing i noticed when going from a 75 to a 79 for work was with the same load the 79 sagged like a coil sprung patrol
they may
well be comfortable enough but upgraded springs will improve things alot
454579
