Tuesday, May 17, 2011 at 20:57
Rainbowprof,
New ball game! Or maybe that’s two ball games, the travelling one and the stationary one!
First – using a good connection from Troopy to trailer will provide charging, but (for reasons given in our blog) you will not get close to full charging. The little trickle charger will not be sufficient to top up and charge the batteries full either. (The solar panel might be very useful for this. Our Troopy carries one on the roof largely for this purpose.)
Quite understand your need to shift the fridge out of the vehicle. Even in a Troopy they take up a lot of space. So let’s assume that it goes to the trailer. One option is to use a 3 way fridge in the trailer, though that involves the initial cost of the fridge plus the cost of the gas installation (there may be legal requirements here too), as
well as cabling and switchgear from the alternator. A 3 way fridge would run on gas while stationary, and 12V direct from the alternator when travelling. Running on 12V is very demanding (12 to 15 amps continuously) and running from batteries is not an option.
Putting the existing fridge (assuming it is a compressor type) with some batteries in the trailer seems the way to go.
At home, being off the
grid, some extra storage and generating capacity sounds very desirable. The difficulty of course is that the Troopy charges when moving and the house doesn’t move! I assume that your domestic requirements are really only for lighting?
Options
It would be pretty inefficient, but you could charge batteries in the Troopy, and later transfer that charge to the house batteries using heavy cabling and a dc-dc charger. This would cost a charger ( $150-350 for 15-30 amps) plus batteries and cabling. The dc-dc charger would also help in charging the battery bank when mobile. Suggest search ebay for “dc-dc charger” – it’s a good catalogue even if you don’t buy there. Some respected ExplorOz business members do advertise there. Look for Derek, ABR, Battery Value…. for quality gear and support.
Another possibility is to carry extra batteries in the Troopy and plug the house into the Troopy battery bank as required. Perhaps one battery in the house to deal with those times that Troopy isn’t home at night, and swap to the Troopy bank (or simply plug the Troopy battery bank in parallel with the house battery) when Troopy comes home. (There will be very little battery to battery charging, and the house lighting will run mainly from the most fully charged battery/ies.) This is probably the least costly option.
Batteries – You are probably already aware - Batteries used in backup supplies for big computer systems are usually discarded long before end of life. It’s worth talking to electricians who deal with these systems. You can often pick some up at no cost when they are routinely replaced. Not all will be perfect, but at that price you can afford to be choosey.
HTH
| J and V
- Albert Einstein
727505
