bush camps spreadsheet
Submitted: Wednesday, May 18, 2011 at 10:33
glids
G’day all,
Some time ago I (Oct 2009?) got hold of a copy of a spreadsheet called "caravannersbushcamps.xls" that lists almost 1750
bush camps, rest areas etc (and a few caravan parks) around Australia. I don't know where the spreadsheet came from, but it looks useful.
An example line from the spreadsheet is:
"Map:25; Ref:G7; BARRABA NSW;
REST AREA; 5Kms South of Barraba; Tables; 48 HRS"
My question:
Does anyone know what Map book is referred to? There are about 90 maps referred to in the spreadsheet.
The spreadsheet has a column for GPS locations, but none are provided.
Thanks,
glids
Reply By: Notso - Wednesday, May 18, 2011 at 10:40
It was probably an extract from Camps AW, the problem is that the map references change from edition to edition so finding which edition it was extracted from is the problem.
454671
Follow Up By: Notso - Wednesday, May 18, 2011 at 10:47
In Camps 5 for instance it is map 28 G7.
Camps use HEMA Maps so it is probably an older version.
727554
Reply By: Member - Duncan W (WA) - Wednesday, May 18, 2011 at 15:00
Glids drop me an email at chunky at q -net dot net dot au & I'll email you the waypoints.
Dunc
454705
