Thursday, May 19, 2011 at 15:50
It should have a 76 Ltr
Tank - I take
mine to the limit, I have put 74ltrs in to it.
The light from my records comes on at about the 60ltr mark - I usually say I have a max of 80k's left after this - for a safety margin.
Mine has run out of
fuel - Follow the owners manual and you will have no issues, it is posted below, put
fuel in the car turn the key on and leave it on for about 10secs, repeat 4-5 times. Try to start, if it does not fire, repeat the bleed sequence. You also have a
water tap on the passenger side, if the
fuel pump is working you should be able to open the tap, turn the key on as per bleeding and have
fuel come out the bleed hose, if you do not you have a
fuel pump issue like I had, noted following; My issue turned out to be the in
tank fuel pump, so the bleeding did not work
well for me...but I can tell you I turned that old girl over and over until it fired. That was about 50k ago and there was not issues.
the in
tank fuel pump costs an arm and a leg (about $580 + fitting) It is the pump and filter unit in one. If it happens again I will be putting in an external after market electric pump.
Cheers Tony
727716
