Rattling Fridge Slide
Submitted: Wednesday, May 25, 2011 at 20:47
Member - DereelGirl
Hi, Has anyone had and solved the rattling fridge slide? I have an Evacool Fridge Mate 55lt tied down to an Evacool slide and it rattles to distraction. I had a thought tonight that I could put some adhesive foam on the inside end of the slide so that when it is pushed
home you would have to give it an extra push and that might stop some of the movement. Any thoughts.
Reply By: AlbyNSW - Thursday, May 26, 2011 at 08:46
Depends wherther it is the slide or a bit of movement in the locking catch that is causing the rattle but putting a bit of tension on the mechanism with some compressible foam etc should sort the problem
455510
Reply By: Evakool - Thursday, May 26, 2011 at 09:07
I have some information and photos that may help you, I have PM'ed you so I can get your email address.
Thanks.
455511
Reply By: Baz&Pud (Tassie) - Thursday, May 26, 2011 at 10:17
We had the same problem, all be it with a different brand.
Got a small piece of rubber and attached to the end of the slide so that there was pressure on it when closed.
Baz
455516
Follow Up By: Member - DereelGirl - Thursday, May 26, 2011 at 12:39
That's exactly what I thought, but you said it much better than my attempt.
As you might have read, Brodie from Evacool has made contact and we might have another solution.
Robyn
728434
