Just mounted the laptop in the Prado
Submitted: Sunday, May 29, 2011 at 20:34
ThreadID: 86630 Views:2588 Replies:2 FollowUps:2
After a couple of trips with the laptop running OziExplorer software and natmaps on the wife's lap I needed an improved mounting position.
I managed to find a Ram Mount for it then I just needed to make up some brackets.
by removing the trim either side of the centre console there are 2 good mounting studs either side that I could bolt to these are the ones that hold the centre console ,
Next I figured that there was just enough room for a .9mm stainless bracket to squeeze between the console and the removed trim, , made up a cardboard template and manufactured a left and right bracket which needed a couple of notches cut out so it didn't interfere with the trim clips. then a top plate with holes to bolt the Ram mount to. with it all bolted together its as solid as a rock.
with the laptop closed for normal road driving it is out of the way and doesn't block my view, then when it is up I am on dirt so not so concerned about a small blind spot .
The ram mount had an optional bracket to stop the lid from bouncing down on rough roads.
I figured that would come in handy on the CSR at the end of June
Image Could Not Be Found
Reply By: Member - Fred B (NT) - Sunday, May 29, 2011 at 20:57
Gooday Ric,
pretty impressive. Wouldn't mind a copy of your templates so I could do the same in my Prado.
regards,
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 455829
Follow Up By: Member - Ric M (WA) - Sunday, May 29, 2011 at 22:24
I have uploaded a pfs of the template here
http://www.ricsdigital.com.au/doc/top.pdf
http://www.ricsdigital.com.au/doc/template.pdf
The template is to scale if printed to A4 and check the dimensions shown.
Cut the stainless with good snips and clean up the edges with emery, I folded the edges over a 100 x 10 flat bar in the vice.
Ric
FollowupID: 728775
Follow Up By: Member - Fred B (NT) - Sunday, May 29, 2011 at 23:52
Thanks Ric,
looks good to me.
regards
Fred B
FollowupID: 728783
Reply By: Member - Andrew L (QLD) - Monday, May 30, 2011 at 10:26
Very neat. Gives me some ideas to change my floor mounted ram.
AnswerID: 455870
