Camp Shower
Submitted: Monday, Jun 06, 2011 at 20:56
Member - Barry H (WA)
Hi all,
Just got back from
camping at
Potters Gorge for the last few nights, and the 12v
camp shower has croaked, again.
Now this is at least the third one in the last 12 months that has given up the ghost in this way, I am beginning to think it is me that is killing them.
I checked the output on the generator ( Yammy) and it was delivering 17.82volts, whilst this may be OK for short bursts I think over a period of time it is burning them out, am I correct or not.
When plugged into the 12v outlet on the CT no result.
This is getting really frustrating.
Barry H
Reply By: dazren - Monday, Jun 06, 2011 at 22:29
Read a thread on another
forum, guy having the same problem ?? he ended up getting a bilge pump for boats, from BCF, said after 4 trips away, he is very happy said it was also rather cheap !! maybe worth a try ??? dazren
456652
Follow Up By: Inland Sailor - Tuesday, Jun 07, 2011 at 09:54
BCF have a few Bilge pumps.....
Any idea which one was used as a substitute pump?
729758
Follow Up By: Member - Bruce C (NSW) - Tuesday, Jun 07, 2011 at 19:42
Hi Barry and Dazren,
I used a bilge pump in a bucket as a
camp shower for many years, many years ago.
They are cheap and easily replaced as they are sold everywhere.
When we moved to this farm there was nothing here so the bilge pump was put on the job again. Never lost a customer but after about 3 years of showers every night it gave up the ghost. I reckon I got more than my moneys worth.
Not only that but they fit right into the KISS principal.
We originally started here with a chip heater and the bilge pump. Can't get simpler than that.
Cheers, Bruce.
729818
Reply By: Greenant - Tuesday, Jun 07, 2011 at 07:58
Hi Barry
I have had one for years no probs but here is what I do. As soon as I am finished using the shower I immediately take the pump out of the
water, the reason for this is :- The air in the pump body would heat up with use and expand thru the shaft seal and when cooling down would suck
water into the motor housing and as they are a cheap unit manufacturing tolerances would not be great so left sitting in
water not running could also be another cause of
water getting into the motor housing and causing a failure.
Greenant
456663
Follow Up By: Member - Bruce C (NSW) - Tuesday, Jun 07, 2011 at 19:43
Spot on Greenant, that is what I found also. Good advice there.
Cheers, Bruce.
729820
Reply By: Member - John and Val - Tuesday, Jun 07, 2011 at 09:45
Barry,
Charging batteries directly from a generator (even the top quality ones) is not recommended because the voltage is unregulated. Without a load such as a battery the generator voltage will be very high, as you've found. I wouldn't expect the cheap little
camping shower pumps to survive this treatment for long.
Suggest run the shower off 12V, not 18 and it will last pretty
well. We've used one for years. Certainly I wouldn't invest in a better, more expensive pump and then run it directly from the generator as it will almost certainly be killed too. Those little pumps don't take much to run, so the vehicle battery won't notice it if you run it from the vehicle.
| J and V
- Albert Einstein
456670
Reply By: Member Al (Sunshine Coast) - Tuesday, Jun 07, 2011 at 10:10
Barry, if you are connecting the shower pump directly to the generator's "12v" outlet and if it is delivering 17.82 volts to the pump then this represents almost 50% over-voltage against the pump's nominal 12 volt rating. A bit much I think. After three failures I would think that this could be a common factor.
The "12 volt" outlet of portable generators is not
well regulated and is designed to deliver the 12v at the typical rated load of 8 amps. At less than 8 amps the voltage will be proportionally higher. As your pump probably uses less than 8 amps it will be subjected to excessive voltage.
Changing to a marine bilge pump may not help as although being probably a better pump it also may suffer from the higher voltage.
A simple way of reducing the generator voltage when using the pump would be to simultaneously connect additional load such as a 12v 60w lamp. This should then pull the generator output down to a more acceptable voltage.
456671
Follow Up By: Member Al (Sunshine Coast) - Tuesday, Jun 07, 2011 at 10:20
John's reply above was posted while I was still typing my response and he makes the good point that I should have - why are you running the shower from the generator rather than from the vehicle battery which will give you the needed 12 volts?
Incidentally, I would not use the "12 volt" generator output for anything, especially battery charging, without carefully monitoring it and knowing what you are doing and the consequences.
729761
Reply By: Member - Duncan W (WA) - Tuesday, Jun 07, 2011 at 10:11
I asked the same question a few months back as I was tired of my cheap 12v submersible pump type shower seizing up. Basically the impella rusts. One reply was to pump a small amount of
water soluble lubricant through it when finished.
I've also been using a bilge pump I picked up from Comec in
Welshpool Rd
Welshpool for a couple of years now as a shower. Works excellent and never a problem with parts seizing up. You get what you pay for. Pump was around the $100 mark. Originally got it so that I could pump out of a
creek if needed. Now have the shower hose and head from the cheapy shower fitted to it.
456672
Reply By: Member - Oldbaz. NSW. - Tuesday, Jun 07, 2011 at 11:04
I had no luck with those little 12v shower things..lasted no time at all, so moved onto
the bilge pump solution..payed $50 odd bucks for one..worked fine for one trip.
Refused to start when checked for next job, so binned it too. Now have a 12v
diaphragm type..off ebay for about $60. I used the switches, shower head etc off the
dud jobs & it works brilliantly. Had to install an adjustable bypass to lower the volume
but easily done. We always like our shower away from the
camp site , & if located
strategically can usually do without screens etc. Power by a Battery Booster means
distance is no problem. We use the same booster for lighting & dont need a battery in
the C/t. Re charge while driving via a 12v outlet in back of Jack. These type of pumps
are similar to those used in caravan & upmarket C/ts.....oldbaz.
456676
Reply By: OREJAP - Tuesday, Jun 07, 2011 at 11:14
Hi Barry, I have used a $20 yellow coloured made in china shower for 5 yrs....the only problem I have had was some grit caused the impeller to stick...I cleaned it...pumped some CRC onto the shaft/impeller & all has been
well for the past 12 mths. I run the shower off a 12v outlet on the side of the camper. I charge the battery on the camper via a 15 amp battery charger/monitor using a Honda genny....I never charge any battery directly off the genny.
456677
Reply By: Farmboywa - Tuesday, Jun 07, 2011 at 21:57
G'day Barry H (WA). Quote"When plugged into the 12v outlet on the CT no result"Unquote. Question. Does the new 12v pump work from the 12v CT outlet for a short time then stop? If so, for a short period of time and then requiring the extra boot direct from the generator, it may be corrosion on the working parts giving resistance. The extra boot needed to spin the impella, eventually destroys the electric motor. Possible remedy. Give the next new pump a spray of WD 40 or something similarly suitable. Probably a good idea to wipe off the excess after the pump has stood for a while. You don't want to walk around smelling like a can of WD40 after your shower.
456742
