Aux fuel tank - need fittings
Submitted: Sunday, Jun 12, 2011 at 22:07
Tim Owen
I've just had a custom diesel
tank made that will gravity feed into the main
tank.
I'm now hunting down some required fittings and are hoping you can help point me in the right direction.
1. I need a
fuel filler to mount to the side of the vehicle (a vertical face), but because there is only a 30cm drop between where the filler will be and the entry point to the
tank, I need the filler to be as sharply angled down as possible. It is a requirement that I be able to lock the fill point.
2. I need to 'tap into' the side of the original
tank toward the bottom (you cannot get to the top of the
tank as the gravity feed will not work). I've read about a method where you drill a hole in the
tank (empty of course), feed a piece of wire down through the original fill point, and out the new hole, then run a hollow bolt down the wire, get the threaded shaft of the bolt through the hole and then put a nut on, remove the wire, and then connect the
fuel line to the shaft of the bolt somehow.
Does anyone know where to source such fittings?
Reply By: Member - Joe n Mel n kids (FNQ - Sunday, Jun 12, 2011 at 22:23
Whitworths have a really good on line catalouge with heaps of fittings in it...
457215
Reply By: Member - Alastair D (NSW) - Monday, Jun 13, 2011 at 08:02
Tim,
I have found Pirtek outlets to be a good source of unusual one-off fittings that I have needed.
457233
Reply By: Ozhumvee - Monday, Jun 13, 2011 at 08:22
Rather than stuff around with the existing
fuel system you would be better off to use a
fuel pump to transfer from the aux to the main
tank, quicker, easier to connect up as you can tee into the filler neck or a breather line on the main
tank.
Also easier to isolate the tanks if you have
fuel problems or a leak in one
tank.
457236
Follow Up By: Ozhumvee - Monday, Jun 13, 2011 at 18:28
I've been using the Whale plastic inline pumps that people fit to caravans to supply
water to the taps, cheaper and with 1/2" fittings really shift the
fuel quickly.
They are rated for use with diesel and I've had two in the Humvee for over 7 years now and one was previously in a troopy for a few years before that.
Like this
Whale pump
Being waterproof and small they can hang in the
fuel line between the tanks. They aren't self priming so need to be below the
tank outlet.
730434
Follow Up By: Tim Owen - Monday, Jun 13, 2011 at 21:33
Thanks - just picked one up from a marine supplier for $56 + shipping at cost. Now I've got another bloody wiring job to do!
730468
