Solar Panels
Submitted: Monday, Jun 13, 2011 at 17:07
Nomad Navara
Can any person tell me if its possible to connect a polychrystaline panel in paralell with a monochrystiline panel? thank you.
Reply By: Battery Value Pty Ltd - Monday, Jun 13, 2011 at 17:18
Hello,
yes, as long as the panels are of the same rated voltage.
They might have a slightly different max power voltage though, so if the solar regulator is MPPT type, it won't be able to harvest max power from both. But it'll be still more efficient than using a PWM regulator.
cheers, Peter
457293
Follow Up By: Nomad Navara - Monday, Jun 13, 2011 at 17:33
Thank you for your info
730425
