Friday, Jun 24, 2011 at 13:15
Maybe check for leaks in the gas plumbing or the thermostat.
As others have posted, my 3-way 55 litre Chescold would run for over two weeks, maybe three on a 4.5 kilo gas bottle - I don't really know because I was never parked up long enough to empty a bottle.
The gas flow is controlled by the jet and the thermostat. Jets may get blocked, they don't open up and allow more gas to pass through, so it's not the jet.
Could be the thermostat not allowing the fridge to cycle, in which case it will burn gasa continuously and overcool - unless you're in a hot environment (tropics?). Is your stuff getting too cold? If it is, then maybe the thermostat is not cycling and the fridge is running constantly.
If that's not it, then maybe there's a gas leak somewhere and that becomes a safety issue to be addressed ASAP.
731800
