Toyota Injector Damage
Submitted: Saturday, Jun 25, 2011 at 11:12
Dennis Ellery
Any injector specialists out there.
Last year my son brought a second hand 2009 model Hilux.
It had 30K on the clock and he has done another 40k.
Of late the engine warning light stays on whilst it is running.
Took it to the Toyota Dealer and was quoted $5000 for repair.
He said that the engine had unleaded petrol put through the injectors sometime in the past.
This would have to been over 40k ago, does this sound feasible?
Is this price about right?
Thanks for any informed advice - Dennis
Reply By: fisho64 - Saturday, Jun 25, 2011 at 12:05
not to me no.
Im assuming its a diesel your talking about though?
Id struggle to believe that any damage done 40K ago could surface now, or how he could tell this was the case unless its noted in the Toyotas service history.
And if its noted in the Toyotas service history then it was repaired by Toyota and covered by their 100K 3 year repair warranty.
But how about some more info-what is the fault code?
Get a second opinion from a reputable diesel mob.
458402
Follow Up By: Dennis Ellery - Saturday, Jun 25, 2011 at 15:50
Yep I should have made it clear - common rail diesel
731887
Reply By: Member - Oldbaz. NSW. - Saturday, Jun 25, 2011 at 14:57
G'day Dennis, all sounds a bit dodgy to me. Has the car any other symptoms other
than the warning light?. There are a few sensors that may trigger it. Take the good
advice already given & seek an independant opinion from a diesel specialist...oldbaz.
458407
Follow Up By: Dennis Ellery - Saturday, Jun 25, 2011 at 15:51
Yep oldbaz - it idles rough
731889
Reply By: garrycol - Saturday, Jun 25, 2011 at 15:14
The check engine light on my landrover came on and the diagnostic said there was a fault when engine shut down. All the so called experts (3 dealers and independents) said it needed new injectors and injection pump costing between $2500 and $3500 to repair.
Not convinced I checked the engine shutdown solenoid which had a little crud where it seats - allowing a little
fuel to dribble into the engine when shut down causing the fault - took 15mins to fix.
Now your problem will be different but the moral is get plenty of opinions as repairers just want to replace things at your expense rather than just diagnosing the problem. Take everything they say with a grain of salt.
As to your costs - I would not have thought that 4 injectors installed would be anything like $5000. Also - don't go to dealers - they often do not know their cars and their labour rates are over the top - not called stealers for nothing.
Go to a independent toyota specialist or even a diesel injection
shop.
Garry
458409
Follow Up By: Madfisher - Saturday, Jun 25, 2011 at 16:40
Unfortunalty common rail injectors for toyotas are $900 ea, , We had a hiace that had bad
fuel put through it and it cost $9000 to fix, with new injectors and pump.
Good luck Pete
731896
Follow Up By: Member - Boobook - Saturday, Jun 25, 2011 at 16:52
I am not sure about all insurers, but last time a similar issue came up on this
forum I checked with my insurer GIO. They said that all repair costs would be covered in the event it was bad
fuel or even if there was a failure as a result of me putting in the wrong
fuel!! If it was my fault, then I had to pay the excess, but if it was bad
fuel no excess. It pays to check with your insurer.
The catch for the OP might be that he probably wouldn't be covered if it happened before he bought it or if it was a while ago.
731899
Follow Up By: lindsay - Saturday, Jun 25, 2011 at 17:19
My brother has one of nthese and it had the injectors replaced at 10 thousand k's was done under warrantee. He was told they did have a problem with them.
731903
Follow Up By: garrycol - Saturday, Jun 25, 2011 at 18:31
Wow - $900 and people say Landrover parts are expensive - a Range Rover Sport TDV6 injector is just over $700.
731911
Follow Up By: Madfisher - Saturday, Jun 25, 2011 at 18:47
Hopefully they will come down in price eventually.
731914
Reply By: MEMBER - Darian, SA - Saturday, Jun 25, 2011 at 17:56
Run Dennis, run - go to a decent small diesel specialist - they probably won't rip off your arms and legs just to look at the car - and if they fix it, after paying for the work you won't end up hating them and everything about them, forever. Hey - you'll probably end up liking them :-o).
458428
Reply By: Honky - Saturday, Jun 25, 2011 at 18:02
A friend had an earlier hilux and when his speedo cable broke the check engine light came on.
Fixed the speedo and the light went off.
Honky
458429
Reply By: AlbyNSW - Saturday, Jun 25, 2011 at 20:23
They did have some injector issues ,
mine is a 07 model and they replaced my injectors under warranty when it was nearly 3 years old due to it being noisy when cold.
I have heard of a number of injector replacements under warranty in the earlier ( 05 to 07 models) but not for a newer one like yours.
As others have stated, unless it is a warranty freeby I would go to a private diesel specialist for a diagnois / repair.
I don't buy the unleaded
fuel 40 k ago story though.
458440
Reply By: Member - John B2 (VIC) - Saturday, Jun 25, 2011 at 21:09
Yes
458446
Follow Up By: Member - John B2 (VIC) - Saturday, Jun 25, 2011 at 21:15
Follow Up By: Member - John B2 (VIC) - Saturday, Jun 25, 2011 at 21:37
My apologies I forgot to Mister Negativity
731940
Follow Up By: Dennis Ellery - Sunday, Jun 26, 2011 at 10:42
John,
I see a list of my previous posts - thanks for that.
I find your other messages confusing – other than telling me to leave a foot print in the sand.
Am I missing something?
731974
Reply By: Member - Serendipity(WA) - Saturday, Jun 25, 2011 at 21:15
Reply By: Ray - Sunday, Jun 26, 2011 at 09:57
It makes you wonder these days regarding these "modern" diesel engined vehicles.
They seem OK till something happens. I can go a long way on $5,000.00 of petrol
458471
Follow Up By: olcoolone - Sunday, Jun 26, 2011 at 16:09
I take it when you mean "modern" your talking about the common rail engines.... that's been around for over 10 years?
Overall very reliable with more power, better economy and easier to drive then the "dinosaur" ones of yesteryears.
The funny thing if there are 10's of thousands of them out there and every now and again you read about ONE failing, reminds me of Michael Jacksons Thriller film clip when all the zombie's come out.... except on a
forum all the knockers come out.
When someone posts a problem about their dinosaur failing they get all the help and support...... the CRD ones just get s_____ given to them.
Why is this so?
732008
Reply By: Dennis Ellery - Sunday, Jun 26, 2011 at 11:12
To all - I appreciate your efforts in trying to sort my son's problem.
It looks like it should be taken to a diesel or injector specialist for a second opinion - and a follow up with the insurer to see if its covered.
458476
Follow Up By: Member - Frank P (NSW) - Sunday, Jun 26, 2011 at 17:26
Dennis, it's a known problem. See the 120-odd pages on the subject in Pradopoint
here.
I had
mine done under warranty and saw the internal bill from the dealer to Toyota - over $7000 !!!!!
I think Toyota need to step up to the plate on this - with so many sufferers it is clearly a design problem.
Frank
732013
