Tuesday, Nov 25, 2003 at 11:48
G'day, here's my two bob worth...
I turbo'd my 2.8 Hilux as soon as the new car warranty ran out in '92. Best thing I ever did !!! It's now 11 years later and just under 300,000 K's and motor hasn't missed a beat. As long as the motor has been looked after (read clean, brandname
fuel, clean filters & oil change EVERY 5000KM, with good oil !!), then all should be
well, it's still a baby !! The turbo won't turn it into a V8, but will give you at least 1 gear better up any
hill, and slightly better
fuel economy (when taking it easy). Towing the caravan means you'll be working the car hard, but won't break it. Cruising on the speed limit is not too hard. Be prepared to be patient up the hills !! The trick is to know the rev's. Don't rev too hard, let the lowdown torque do the work. I tow a camper which weighs at least 1000kg, and find that down changes are not done until 2200RPM, with up changes at between 3000-3500. 3500RPM is about as high as you want to rev at any time. The drive train seems to handle the work OK, although I have broken diff pinion gears, but I don't think this is related to the turbo (long story). My gearbox is starting to become a little growly, especially in third, but it's still a long way off before I'll have to touch it. Clutches may be your only drama. Standard clutches won't last, they simply aren't strong enough. I've been using a "heavy duty" replacement clutch (brand name escapes me) from my reputable local auto parts store, for about 150000km, with absolutely no problem. The pedal pressure is about the same, just starts at higher position (not even the ex complained !!). The clutch takeup and feel are about the same. The intercooler would be a good idea as the car does seem to lose a bit of power when working hard on hot days. It definitely runs better on cooler days.
Overheating could be a problem. I find that the engine does have a tendency to run VERY warm when working hard on hot days. Never boiled or had to actually stop, but I have had to turn off air-con and slow down on really hot days. Intercooler wouldn't help this.
Look for a turbo that is
water cooled, not just oil cooled. A Garrett T2.5 is very good. You want a system which has lots of boost down low (at least 7psi at 2000RPM). Pressure will actually rise at higher RPM (
mine goes to 13PSI @ 3500). Disconnect any wastegate. Diesels are very different to petrol motors. For a petrol, too much boost means too lean a mixture, means too hot, means motor goes (expensively) bang. More boost in a diesel means more air, means leaner mixture, which means runs cooler, which means better !! As the
fuel flow rate is fixed in HiLuxes (due to mechanical injection and no computers), there is no chance of the motor self destructing due to "overboosting".
The bigger, reputable companies all seem to do a good job, but it does take a little talent to get the injector pump tuning right. Be wary of anybody who simply "cranks up the pump until it blows smoke and then backs off a little". There seems to be a bit more to it, to get it right.
Bored or lost yet ??? Sorry, I get carried away !! There's more to the story, but the short version is: do it, you won't regret it !!!
Regards,
Dave
38350
Follow Up By: wizzer - Wednesday, Nov 26, 2003 at 17:57
Dave
I was curious about the disconnecting wastegate comment. Do you mean remove the pipe from it or block the pipe up or something else?
Has anyone else done this.
wizzer
28563
Follow Up By: Tonksy - Wednesday, Nov 26, 2003 at 19:32
Hey Dave,
I have a 98 Td Rodeo with aftermarket intercooler. With the factory turbo only putting out about 5psi, am I gonna cause damage at all by adding a boost controller and adjusting to 10psi or near about? Or should I be adding more diesel and monitoring with a pyro.
28573
