UHF AERIALS
Submitted: Friday, Mar 29, 2002 at 01:00
ThreadID: 888 Views:2458 Replies:4 FollowUps:1
I HAVE A 3 PIECE UHF AERIAL NAMELY 3DB-6DB-9DB.CAN SOMEONE EXPLAIN IN WHAT SITUATIONS YOU WOULD USE EACH AND IS THERE AN INCREASE IN OUTPUT WITH THE HIGHER DB RATING'S.I CURRENTLY USE THE 6DB SECTION IN COASTAL AREAS BUT OCCASIONLY USE THE VEHICLE IN FAR WESTERN QLD.ANY ADVICE PLEASE.
Reply By: rich - Friday, Mar 29, 2002 at 01:00
chris,
the simple lowdown..3db - hilly, higher waveshape, more likely to traverse slopes and ravines. 9db - long waveshape, more likely to recieve remote area contact in FLAT country.
Personally, I'd throw the 6db section away...
cheers Rich
AnswerID: 2551
Follow Up By: Chris - Saturday, Mar 30, 2002 at 01:00
RICH.
THANKS FOR THE INFO, BUT I HAVE TO KEEP THE 6DB SECTION AS THERE ARE 3 PIECES THAT ADD UP TO 9DB.STILL DOESN'T EXPLAIN WHAT THE 6DB IS FOR.CHEERS.
FollowupID: 952
Reply By: P.G. (Tas) - Saturday, Mar 30, 2002 at 01:00
Chris, Rich hit the nail on the head. The 6db is a step in between the 3 & 9db gain antenna's. I use a GME AE409L which is 6db/9db. The 6db is fine around town and most rural area's in Tasmania, in fact it is far better a lot of the time than the 9db. When I tour the outback though, there is no comparison, the 9db is the way to go. This is through an old Electrophone TX4000. If I can find a better setup I will buy it, but as yet this is it. Hope this helps. Cheers
AnswerID: 2563
Reply By: rich - Sunday, Mar 31, 2002 at 01:00
Chris,
Of course you need the 6db bit, sorry. Not thinking....
Try this: http://www.roity.com/rc/cbradio/uhfcb.html
It should explain everything.
rich
AnswerID: 2564
Reply By: Darian - Thursday, Apr 04, 2002 at 00:00
The GME site (www.gme.net.au) has some good info on the antennas page. I have the 6/9 electrophone unit too - my research suggests that the 9 configuration is really good for long distances, but only when the car is stationary - when it flops around while mobile, the signal often goes UP instead of along!. In the (undulating) desert awhile back, the best performance for UHF in our group was a stumpy little 150mm unit. Taught me a lot - have made some of my own quarter/half/5/8 wave UHF antennas now, out of staineless wire - seem to work really well - they are all shorter than the 6db set up. Seems tall antennas have a long skinny pattern (like a pancake) and short antennas have a fat local pattern (like a donut) as explained to me by an expert). I made a page about my project - could be of use (http://homepages.picknowl.com.au/darian/uhf.html).
Cheers /
Darian
AnswerID: 2616
