TV antenna for caravan to replace Happy Wanderer T Bar type.
Submitted: Tuesday, Sep 27, 2011 at 10:35
Fred G NSW
Just wondering if anyone is using one of
THESE and if so, looking for any feedback re same.
I am looking to replace the old T bar, which has been sensational I might add, but doesn't support the digital channels on my new Kogan TV very
I can still use the old mast and fittings with the new antenna.
Reply By: Rockape - Tuesday, Sep 27, 2011 at 17:13
Fred,
That antenna looks like the state of my eyes after I have had a few to many cool drinks.
Have a good one,
RA.
466173
Follow Up By: Fred G NSW - Tuesday, Sep 27, 2011 at 19:56
LOL
I had similar thoughts RA
Fred
740267
Reply By: snapper49 - Tuesday, Sep 27, 2011 at 20:06
I have a kogan and also a happy wanderer TBar works perfectly on digital channels
Over a period of time the cables have been known to break just inside the housing
Pull it apart and just check connections
Just a matter of making new ends and re attaching
466188
Follow Up By: Fred G NSW - Wednesday, Sep 28, 2011 at 09:10
Thanks for that suggestion snapper. I'll check it out today. All my analogue channels are okay, just the digital no good.
Fred.
740301
Follow Up By: Member -Dodger - Wednesday, Sep 28, 2011 at 17:14
lso in some areas you may have to go vertical.
To do this pull off one of the rubber ends on the crfoss bar then insert into the uprite tube. Great for Qld where often the signal is vertical and not horizontal.
Also as said above there may be a broken wire in the balum which is worth a look.
740333
Follow Up By: snapper49 - Wednesday, Sep 28, 2011 at 18:06
I dont believe this to be so for digital signals
Was the case for the old fm tv signal
I live in
whyalla where fm now doesnt exist only digital and yes for fm we had to have vertical but not for digital we are digital only now as same as the riverland
740341
Follow Up By: Fred G NSW - Wednesday, Sep 28, 2011 at 18:25
Thanks Dodg. No go. Think I'll replace the whole cable tomorrow, with the heavier black one, rather than the skinny white one on it, which has been out in the weather on and off for 2 1/2 years now.
I have a digital signal, but it's like a chessboard with every second piece missing for a few secs, then says NO Signal..
snapper, is yours the happy wanderer T ?
Cheers fellas.
Fred.
740347
Follow Up By: Fred G NSW - Wednesday, Sep 28, 2011 at 18:27
A seniors moment there snapper, off course you told me above its a H/W
Fred
740348
Follow Up By: snapper49 - Wednesday, Sep 28, 2011 at 19:41
yes T have used it all across sw west aust all around
alice springs and in
adelaide and all over eyre peninsula with out any problems receiving digital signals perfect reception and in the horizontal position
Definately souds like you have a connection problem ie a break in the cable somewhere
740364
Follow Up By: snapper49 - Wednesday, Sep 28, 2011 at 19:42
sorry yes happy wanderer T
740365
Follow Up By: snailbait (Blue mntns) - Thursday, Sep 29, 2011 at 08:19
Hi all
The hi definition tv does not cover all of Australia yet the run out ends in the end of 2013 so you will get some channels on the the pre digital antenna. The one i have did not work In Tasmania as they have nearly changed over to HI Definition and use Vertical signal I have changed over to a wind up aerial with a extra bit attached on the side to catch the vertical signal.
Safe travelling
I am off tomorrow for 8 weeks in Qld then Vic
Terry
740395
Follow Up By: snapper49 - Thursday, Sep 29, 2011 at 08:52
from happy wanderer quote:The Happy Wanderer T-Bar Antenna is simple to erect and stow away. It tunes to both horizontal and vertical polarised signal and can pick up UHF/VHF TV and FM radio reception, as
well as being able to pick up digital signals.
The original T-Bar anetenna is a budget priced antenna which can be coupled with our optional Amplifier/Booster (see this in our other products menu under HW024G). The T-Bar antenna has proven over time to be one of Australia's favourite RV antenna's with over 120 000 sold in our 20yr history.
DIGITAL READY and performance can be enhanced with the use of our Digital ready BOOSTER/AMPLIFIER range.
http://www.happywanderer.net.au/
740398
