Question: VMS Touring 700HD On & Off Road
Submitted: Friday, Oct 07, 2011 at 18:21
Member - John C (INT)
Can you by upgraded maps every year or so. John C
Reply By: Member - Brenton H (SA) - Friday, Oct 07, 2011 at 20:49
John, this is probably not in line with your question but in considering 700HD recently I had the opportunity to take it to the car in sunlight and the screen was almost unreadable. I didn't proceed with the purchase. New units on the market thes days promote the virtues of WVGA-800X480 screen resolution which makes images sharper...yes, but unless the hardware (the screen) has sufficient luminosity (brightness) you cant see it any way in
bright sunlight in the car in a real world situation.
(I feel that unless you can SEE the screen most everything else is irrelevant)
467039
Follow Up By: Member - John C (INT) - Friday, Oct 07, 2011 at 22:42
Thanks for the info good point. John c
741155
Reply By: ExplorOz Team - Adele - Monday, Oct 10, 2011 at 15:42
Hi John,
The VMS uses where IS street mapping, and updates are usually made available on a yearly basis, these are supplied on SD card, and cost between $100 - $200. I've just included this information in the product description as
467263
