The efficiency of fire extinguishes!!
Submitted: Sunday, Oct 09, 2011 at 18:28
Axle
After a relaxing day watching the
Bathurst races, The DJR Racing crash is certainley a reminder of how important a fire extinguisher is , in different circumstances,
camping, caravaning, or where highly inflamable
fuel is contained in a vehicle, or container,bottle or what ever, things can happen!!
Cheers Axle,
Reply By: Member - Phil G (SA) - Sunday, Oct 09, 2011 at 19:17
Got to admire the way those guys used them too - with fire going everywhere, they waded into it to protect the driver who walked out untouched. Very good work.
Great day for sport - I found myself flicking between
Bathurst, the SANFL grand final won by my local team by 3 points, the Rugby won by Aus by 2 points and the F1 where Vettel took out the title......geeze- that was a busy afternoon in the chair! My wife was in front of the other TV watching the Aussies win the Netball!
467206
Follow Up By: Axle - Sunday, Oct 09, 2011 at 20:01
LOL!! Phil,.... Thought i was Bad.
Cheers Axle.
741321
Reply By: Member - Toyocrusa (NSW) - Sunday, Oct 09, 2011 at 19:44
Hi Axle. I often wonder how many people carry an extinguisher in their vehicle. Should be mandatory in all motor vehicles in my opinion. Bob
467208
Follow Up By: bibtracker - Sunday, Oct 09, 2011 at 19:48
Got a 1kilo job the other day. About $23 from Bunnings. Seems like damn cheap insurance . . . or it will be when I take it out of the semi-retired Magna and put it into the 4WD!
Cheers, Tony
741320
Follow Up By: Axle - Sunday, Oct 09, 2011 at 20:06
G/Day Bob, Thinking the same way!
Cheers Axle.
741322
Follow Up By: Member - Joe n Mel n kids (FNQ - Sunday, Oct 09, 2011 at 20:11
we have 2, it also needs thought as to where you mount it, if something catches fire are you able to stop, get out quickly and get to it to put out the fire ????
My main reason was the 2 aux batterys in the back and spiders web of wires, yes all fused ect but with gravel road, heat and dust you can always expect something to wrong when you dont want it to ...
741323
Follow Up By: Member - Rob Mac (QLD) - Sunday, Oct 09, 2011 at 22:22
That's why
mine is mounted on the floor by the drivers
seat right hand side. I take it out every now and then and give it a shake. My work gives us fire training every couple of years so I know how to use it, plus I put a fire out on a
fuel tanker I was driving in
Tom Price in the 80's.
741330
Follow Up By: Member Andys Adventures - Monday, Oct 10, 2011 at 08:04
I carry 2, 1 kg dry powder, one behind the drivers
seat and one in the back near the stove, and have the shower as a
water spray for small grass fires. But be aware that if you have a small power station in your car, eg 1600w
inverters and charging systems or solar, don't use
water based extinguisher. Remember to inspect them on a regular basis, at least every 3 months Replace every 2 years, even if they look OK. I've had one that was only 3 years old, looked ok, was in the green but didn't work.
741350
Reply By: Goldmad - Sunday, Oct 09, 2011 at 22:10
Got to agree. I have 3 plus a fire blanket. Got to remember to shake them up if needed.
Pity about some people though, see some guys on the news pouring petrol on a bonfire
with flames less than a meter away. Yes you guested it there was a explosion, one
badly burnt.
467218
Follow Up By: Member - Rob Mac (QLD) - Sunday, Oct 09, 2011 at 22:27
I saw the promos for the news of this incident and thought it ironic the same tv station advertising some competition for aust biggest richard cranium where some bloke throws flammable liquid on a fire and it flares up.
741331
Reply By: Mick O - Sunday, Oct 09, 2011 at 22:22
Even more important than carrying a fire extinguisher is fire extinguish maintenance. No point having one if you go to use it and she no work like she's supposed to.
Constant travel can cause the contents of the dry powder type extinguishers to settle and compact. Always a good idea to turn the extinguisher upside down and knock it against a tyre or something firm (But will not damage the extinguisher) to free up the contents. I do this weekly when travelling on the rough outback roads or off country.
You also need to be aware that different fires will not necessarily be extinguished by your standard type powder extinguisher. For example, spinifex gum may continue to smoulder and reignite if hit with a powder extinguisher.
Water is your saviour here.
Always check the pressure dial on a regular basis to ensure your extinguisher still has a pressure charge in it. Handles and trigger mechanism are often plastic and susceptible to damage so also need checking.
Food for thought.
Cheers Mick
467221
Follow Up By: Member - Toyocrusa (NSW) - Monday, Oct 10, 2011 at 06:43
Hi Mick. I ran a Service Station back in the 70/80's. We had a
young bloke fill up a trail bike with an off road (larger)
tank that had a small leak. When he went to kick start it it caught fire. A large powder ext just seemed to make a mess and the flames kept burning through the powder. In desperation we grabbed a hose and although it spred the petrol the
water evetually put the petrol out. After, the firies arrived and on reflection they said powder was not ideal for that type of fire and to use BCF at that time (now obsolete) I now carry a 2kg carbon dioxide. I have had to use one twice on small fires in my workshop over the last 10 years and they seem to work
well. Also no powder mess to clean up afterwards. Cheers,Bob
741348
Reply By: Member - Serendipity(WA) - Sunday, Oct 09, 2011 at 23:09
I have one fire extinguisher mounted next to the drivers
seat and a second one mounted in the camper near the cooker. I regularly rotate my extinguishers.
I also have a fire blanket in the camper attached to the front of the fridge - close to the cooker but not so close as not being accessible in a fire when cooking.
I also have a 2 litre pressure pump bottle with soapy
water that can have multiple uses like putting out spinifex fires under the vehicle, helping to
seat the bead on a tire or just cleaning the bugs off the windscreen. This pump is readily located in a side compartment of the camper on the drivers side for quick access. One thing I need to setup is a long wire hooking piece to get spinifex out from where it might be stuck.
I think it is a good message to others to know what people do to be prepared when out
camping.
I think people might remember the unfortunate camper in Alice caravan
park a year or so ago who burnt his camper to the ground when a loose fitted hose on the gas stove lit up the canvas on his camper. There might not have been much he could do as I would imagine it going up very quickly but an easy access extinguisher might have stopped it and a fire blanket over the gas stove might have stopped that too.
Always helpful to share the knowledge.
Serendipity
467222
Follow Up By: Member - Brenton H (SA) - Monday, Oct 10, 2011 at 09:31
Been thinking about that hooking piece myself, but may already have a few items on board already we could use or rig up in an emergency:
Long metal hook that I use to pull tent pegs out of the ground without bending.
Extendable tent pole with a wire hook
The
metal pole stands for hanging cooking implements over fires
And probably a few others I haven't thought of
741356
Reply By: Member - Troll 81 (QLD) - Monday, Oct 10, 2011 at 10:34
I have 3 2 either side of cargo barrier and one in the camper. Many years ago in my old Hilux I had one mounted in the tray and thank goodess I had it becasue I had a under bonnet fire.
467238
Reply By: Member - Alastair D (NSW) - Monday, Oct 10, 2011 at 13:33
Axle,
I agree with all the above comments and especially by Phil G at the preparedness of the volunteer to go straight into the fire.
It was interesting to see that when the
fuel cell ruptured and spread
fuel everywhere the fire did not start immediately at the car. The ignition point was somewhere upstream of the car and took a while to spread. I replayed the segment several times but the ignition point was out of picture and the commentators seemed to not notice it.
alastair
467256
Follow Up By: Road Warrior - Monday, Oct 10, 2011 at 16:10
Yeah I noticed that too, what the...?
741372
