cryovac meat
Submitted: Thursday, Nov 10, 2011 at 11:29
ThreadID: 90010 Views:5709 Replies:11 FollowUps:9
We have a waeco cool-ice eski. Supposedlly keeps cold days after ice has melted. So far has't let us down.
Normally when we go camping we freeze all our meat first and then pack it in the eski with blocks of ice. Always find the blocks last much better than a bag of ice cubes.
Today was talking to my butcher and he suggested I cryovac the meat then freeze it as it will last much longer. Sounds like a good idea and he offered to do it for free, so will certainly try it.
Just wondering, does anyone else have experience using this method to keep meat fresher longer?
Reply By: Member - cuffs (SA) - Thursday, Nov 10, 2011 at 11:41
I recently came back from a 5 week trip, I cryovac all the fresh meat, cooked meat, stews and Pizza. Nothing was frozen just carried in the fridge. Pork & chicken do not last as long so I buy fresh as I travel if possible.
From experience 5 weeks is about the limit for refrigerated meats.
AnswerID: 469624
Follow Up By: get outmore - Thursday, Nov 10, 2011 at 15:48
cryovaccing cooked food is a very , very , very bad idea
FollowupID: 744069
Follow Up By: Dave(NSW) - Thursday, Nov 10, 2011 at 16:58
I can't see any difference to putting left overs in a container and freezing it.
Cheers Dave.
GU RULES!!
FollowupID: 744073
Follow Up By: get outmore - Thursday, Nov 10, 2011 at 18:14
huuuuge difference
packaging food with the absence of air is exactly what canning is
now heat treating cans to eliminate botulism is a real science
freezing food disables bacteria to grow and multiply
vaccume packing cooked food just inhibits the ability of normal spolage bacteria that would tell you the food is off but wont stop an anaerobic bacteria growing the worst as mentioned which is botulism
FollowupID: 744082
Follow Up By: Member - John and Val - Thursday, Nov 10, 2011 at 19:54
I assume you mean vacuum packing precooked food but not freezing it? If its frozen and kept frozen I can't see any problem - its the same as storing it in the freezer at home.
J and V
- Albert Einstein
FollowupID: 744103
Follow Up By: get outmore - Thursday, Nov 10, 2011 at 20:07
Yes thats right
FollowupID: 744109
Reply By: Bushranger1 - Thursday, Nov 10, 2011 at 11:47
Cryovac works great.
I get it done whenever I can. Except if you have sharp bones then it can puncture the bag.
Stu
AnswerID: 469625
Reply By: Member - John and Val - Thursday, Nov 10, 2011 at 12:13
Works best with red meat with no bones as they can puncture the bag. If you want to cryovac chops use pieces of the meat trays that supermarkets use to package meat. Place the meat between the pieces of try to stop the bones rubbing through the bag.
Chicken and pork dont keep as long as red meat. Sausages and mince are OK too. WE have our own machine and also use it to store preprepared meals. When they have cooled we freeze them in a suitable sized container then remove the frozen block from the container and slip it into a cryovac bag and seal it up.
We usually freeze meat before we pack it in our camping fridge. As the frozen meat goes in the bottom of the fridge we have learned from experience to pack the meat into sturdy plastic containers. If this is not done the weight of the fridge contents on top can puncture the cryovac bags, especially if you are travelling on corrugated tracks.
Val
J and V
- Albert Einstein
AnswerID: 469627
Follow Up By: gordon_adel - Thursday, Nov 10, 2011 at 13:31
Good sound advice. Thank you everyone.
My wife is the one who organises packing as she is freak when it comes to organisation. Things are always packed in plastic and then in tupperware. I reckon she's got every shape and size available. Have found that tupperware is the best. On side note, seems for our camping gear we usually go with top quality because otherwise you pay later for the small savings buying cheaper quality.
John and Val, what brand machine do you have? I think I'll seriously look into getting one.
FollowupID: 744060
Follow Up By: Member - John and Val - Thursday, Nov 10, 2011 at 19:52
Ours is from eBay - Maxkon, and we get bags from eBay too. It seems to do the job quite OK, given that it does not get a huge amount of use. It was a lot cheaper than the name brand machines.
Also to clarify, we keep precooked meals frozen after we have vac packed them and have never had any problem.
Val.
J and V
- Albert Einstein
FollowupID: 744102
Follow Up By: AlbyNSW - Thursday, Nov 10, 2011 at 20:53
We have the same Maxkon unit and it works just fine, this is one of the best cooking accessory we have, saves a lot of fridge storage space and makes meal preparation easy
FollowupID: 744117
Reply By: gordon_adel - Thursday, Nov 10, 2011 at 13:50
I was just googling and came across an older thread from this siste.
http://www.exploroz.com/Forum/Topic/44446/DIY_Cryovac_Systems.aspx
AnswerID: 469637
Reply By: the_fitzroys - Thursday, Nov 10, 2011 at 15:39
Hi Gordon,
Been through all this as well. One thing you need to be aware of is that once the meat thaws the cryovac seal is broken. ie. you can't then keep it for 3 weeks or whatever at fridge temperature. We used to freeze our cryovac meat but don't do it any longer for this reason.
Pork and chicken actually last less time in cryovac as they emit some sort of enzyme or vapour once they're cryovaced that makes the meat break down more quickly. So best to take these fresh and eat them earlier, or buy fresh on your travels.
Lou
AnswerID: 469648
Reply By: Hi-ryder - Thursday, Nov 10, 2011 at 17:49
Hi gordon i am a butcher cryvac is the best way to keep meat but you still must keep it under 5 degrees at all times . Pork and chicken will go off quicker than your red meats . colder the better . If its not kept under 5 degrees it still will go off . Cryvac takes the air out of the bag and then seals it good when in ice becuse water wont get into your meat . hope that helps
AnswerID: 469658
Reply By: Joshane - Thursday, Nov 10, 2011 at 18:48
Hi there
Your butcher is right...your meat will last much longer if you cyrovac and then freeze it. We always get our butcher to cyrovac our meat for us before we go on a big trip.
We also freeze it, and have never had any problems with any of the meat or chicken we have bought. Our fridge/freezer holds about 4 weeks worth for our family of 4, and I haven't had any go bad yet.
Your butcher will be able to tell you what you can or cannot cryovac.
Jodi
AnswerID: 469662
Reply By: the_fitzroys - Thursday, Nov 10, 2011 at 18:52
If you're going to freeze cryovac meat it's a good idea to get your butcher to do it and pick it up just before you leave. They can get it more quickly and solidly frozen than you can in a domestic fridge, esp. when you put quite a lot in together. It may feel rock-hard frozen on the outside but it isn't always inside.
Lou
AnswerID: 469663
Reply By: gordon_adel - Thursday, Nov 10, 2011 at 20:04
Wow lot's of thoughts here.
As I'm only going away for two weeks I reckon I'll be fine. As the mrs always keeps a running log\diary of everything, when we're back I''ll ask her how we went with it and report back.
AnswerID: 469676
Reply By: Member - John Baas (WA) - Thursday, Nov 10, 2011 at 21:36
We've had good results with cryovaccing, just running our Engel as fridge (not freezer) but when we return home and we freeze the unused stuff (never has been pre-frozen) we have found that anything on the bone, such as chops, goes green very quickly the second time around, following defrosting, on the next trip (still in the cryovac). Be careful if doing this.
Now, we just consume those unused chops etc as soon as we return, and don't freeze for later.
Cheers.
AnswerID: 469682
Reply By: Member - Bucky - Friday, Nov 11, 2011 at 04:50
Gordon_Adel
Most Butchers can, and will Cryovac meat, if you ask them
But
In 2009 we did a 3 month trip covering The Gunbarrell, the Canning and the Kimberley. just had the odd Pub, or Roadhouse cooked meal
We were away for 3 months, and SWMBO dod approx 80 meals.
Cryovaced them all and staced them into the 40 lt Engle (same thing as a Waeco).. All sealed in meal lots, and laid flat in a freezer, then strategically mixed, and transfered into our Engel 2 days before we left.
We had some left by the time we got home, and were all brilliant.
SWMBO dod roasts, curries, Spagetti bases, and just about all our favourite dishes.
Instant Potatoe mix was the go and if done with UHT milk, you can hardly tell the difference. Peas, corn ect, were freeze dried..
We lived like kings (and queens)
Those little Units are available at Harvey Norman, and at Aldi, if you watch for them. They are also available over the Net
Bucky
AnswerID: 469701
Follow Up By: Member - Bucky - Friday, Nov 11, 2011 at 04:52
By the way...... dod really means did
FollowupID: 744139
