Timing belt 1HZ motor
Submitted: Monday, Nov 14, 2011 at 15:00
ThreadID: 90096 Views:10515 Replies:5 FollowUps:5
Hi all
Need to change my timing belt and as this is the first time I have done one on this type of motor, any hints would be appreciated. Repair manual a bit vague.
Mike
Reply By: Bob Y. - Qld - Monday, Nov 14, 2011 at 17:03
Muddy,
Haven't done one for a couple of years, but can't remember any dramas with the procedure.
Just make sure you line up the timing marks, after removing the cover, BEFORE you do anything else. I'd check that the new T-belt you have is the same as the old one, before you remove it.
Depending on how many clicks the vehicle has done, you might want to replace the idler pulley too. Seem to remember that one or two of the notched pulleys might have a bit of free play in them, so just make sure that the pulley/s don't move too much, & throw everything out by a notch, once you've removed the old belt.
Good luck,
Bob.
AnswerID: 470007
Follow Up By: get outmore - Monday, Nov 14, 2011 at 18:42
Make that definitely need to change the idler pully when I got mine done it was on the way to failure and was discoloring from heat.
Mechanic said he is frequently called out to places where they can't start the cruiser after changing the belt. By then its too late and the head is lunched. Mate at work was set back 2k after doing this simple job
FollowupID: 744465
Follow Up By: dbish - Monday, Nov 14, 2011 at 19:32
Unfortunately i cant post pics here as i took photos of one i did recently. Its very easy to do . after removing the cover turn motor over till the 2 pulleys & there timing marks line up. Remove idler pulley & fit new one & fit new belt.
FollowupID: 744473
Reply By: aussiedingo. (River Rina) - Monday, Nov 14, 2011 at 20:01
G'day muddy, motor needs to be at BDC (bottom dead centre, before you start- which is unusual).....hoooo roooo
AnswerID: 470030
Reply By: Member - Muddy79 - Monday, Nov 14, 2011 at 22:58
Thanks guys. Just another question, how do you rese the dash timing light.
Mike
AnswerID: 470048
Follow Up By: get outmore - Tuesday, Nov 15, 2011 at 00:41
depends on the vehicle - i removed the rubber grommet on the speedo display and poked a sturdy cable tie through holding it down for a bit
thats an 80 later models i cant recall how its done but its different
FollowupID: 744501
Follow Up By: Smudger - Tuesday, Nov 15, 2011 at 15:13
Remove rubber grommet and use a skewer or similar. Be gentle when you push the reset button, it is easily pushed through the back of the instrument panel.
FollowupID: 744541
Reply By: Member - Joe n Mel n kids (FNQ - Tuesday, Nov 15, 2011 at 00:04
Hi Mike, the timing belts on 1HZ's are a very simple job but be warned, many, many engine failures lead back to a poor timing belt change out, one BIG mistake people make is how they lever the idler pulley to relese the tension to remove the belt and they very slightly bend the backing plate, hardly noticable but over the next 10-30,000 klms it will gently run the belt off, it will stress the belt on one half and one day in the middle of noware it will snap at about 3000rpm, valves will make contact with pistons and motor WILL be destroyed, no if's, maybes or buts it will be ruined .....
It is not hard to pick it up after as you find a black rubbery dust around the inside of the timing belt cover, you will NOT find that if the belt runs perfectlly ....
So with that in mind be VERY careful, replace the idler pully, bolts and backing plates and if you are not to sure get someone to do it and DONT go the "cheap" job, so many brag about how they can do it in 1/2 an hour bla bla bla and it is simple, any fool could do it and so on.... check out the "LCOOL" site and you will see what i mean, for me i would get someone with a good reputation to do it and offer you some warrenty, even $800 bucks is cheaper than a tow job from 500klms away, and the accom and so on...
Joe
AnswerID: 470055
Reply By: Member - Trouper (NSW) - Tuesday, Nov 15, 2011 at 12:30
Was intending to do mine on the 2000 model Troopy back in May but decided to have it done by the local Toyota dealership after they quoted $180 supply and fit. Preetty cheap I thought and a garrantee as well
cheers...............jeff
AnswerID: 470075
Follow Up By: Smudger - Tuesday, Nov 15, 2011 at 15:18
I agree with Trouper. Do most stuff myself, but had mine done by the mechanic the labour cost was minimal. Only a 20 minute job for a bloke who does it often.
FollowupID: 744542
