Great central road.
Submitted: Sunday, Nov 27, 2011 at 21:09
Warren B
Just an idle question out of left field, has any of you more intrepid travellers taken a van along the
Great central road ?,if so what type ?. Now we are not about to rush out and start the trip today. it will be about 18 months before we can tell the boss to shove it for good, but i were reading a back issue of on the road which featured the centre road and i got to thinking ( dangerous that ). thanks in advance.
warren
Reply By: Member - Jon W (Toowoomba QLD) - Sunday, Nov 27, 2011 at 21:15
Hi Warren,
We crossed it in June of 2006 with a CT. We saw several vans and they did not appear to be having trouble. There was nothing that a van with reasonable clearance and A/T tyres would be troubled by.
The WA section was better than the NT section at that time.
We did
Yulara to
Laverton in two days easily.
Jon W
471142
Reply By: SuperGrover - Sunday, Nov 27, 2011 at 23:21
Hi Warren
We travelled the GCR last year in July in a 19'6 Supreme Territory towed by a Hyundai Terracan. We were very inexperienced at the time and failed to reduce our tyre pressures sufficiently. The road was very wide and the vision clear however there were a number of corrugated sections which certainly gave us the shakes. The road conditions vary considerably depending on the weather and graders. A semi offroad caravan with reasonable
suspension should not have many problems just drive to the road conditions and drop your tyre pressures and speed. The WA side was definately better.
471152
Reply By: Motherhen - Monday, Nov 28, 2011 at 01:14
Hi Warren
We have, coming home from a trip which included the
Gibb River Road, including to
Kalumburu, to Alice Spring via the Tanami, and touring around Central Australia including the
Mereenie Loop and to
Chambers Pillar. The only breakage occurred on the Great Central but wear and tear in the preceding months needs to be included. It was only bolts holding a caravan spring, but when you are a long way from anywhere the consequences of any breakdown can be major. We were lucky that we were able to back track and find the brackets (on a road littered with flotsam from vehicle as a testament to its roughness) and that we found in our spares the right sized bolts.
As said, conditions vary greatly; week to week even day to day, but there will always be good and bad sections. If tackling a remote road like that, you need a good off road caravan and to be self sufficient and resourceful in case something does go wrong because of remoteness.
My 2008
blogs include the GCR, and my 2009
blogs the easier but more remote
Gary Junction Road. Both are lovely drives; particularly the
Gary Junction.
471155
Reply By: Member - Captain (WA) - Monday, Nov 28, 2011 at 05:57
Hi Warren,
We did this trip in July with our Quantum, a full offroad van. We had zero issues but upon our arrival in Uluru we met a couple who had towed a Jayco and they had several issues related to the corrugations. Unsure what tyre pressures they ran, but it was vibration damage they had. Ground clearance is not really an issue, unless you have a super long, low slung mammoth. Basically if you can easily mount a large kerb in K mart you will have enough ground clearance.
Here is a link to my blog of the trip, note how unusually wet it was.
Our Uluru trip Blog
Captain
471157
Follow Up By: Warren B - Monday, Nov 28, 2011 at 21:03
hi captain,loved the blog but with a 3am start tomorrow the photos will have to wait.
the rock pics bought back memories of our 94 trip.
Chees warren
745766
Reply By: Member - Frank P (NSW) - Monday, Nov 28, 2011 at 08:15
Hi Warren,
As everyone else has mentioned - tyre pressures and also, reduce speed.
We have BFG T/A all terrains, highway pressure in the off road caravan 45PSI
On the GCR, 25. Same in the car. Stuck to 60kph and no problems at all.
471166
Reply By: Warren B - Monday, Nov 28, 2011 at 20:48
Thanks for the replies guys, we have a 21' crusader h/duty axles, roller rocker
suspension, with shockers, lifted 4'' and 15'' rims and off road tyres. we picked the van up on a friday and left on monday went to turlee, mungo,
menindee,
milparinka, wari
gate, noccundra, innaminka, strezlicki track and flinders. had no problems at all so now i reckon that the van will be ok. and yes motherhen i do follow your blog and read your posts. its good to get info from people who are out there doing it rather than writing about what they have read.
warren
471220
Follow Up By: Holden4th - Wednesday, Nov 30, 2011 at 20:52
Compared to where you've just been the GCR will be like a highway. I did the trip in 07 from
Perth and until I left the
Laverton Shire the road was better than many of the bitumen highways I've driven here in QLD. The road changed dramatically when I crossed into the next shire but I still manged to comfortably travel between 90/100 kmh. There was a very sandy section in the NT around Docker River and this is the only section of the GCR where real care is required. I believe that you could do this whole trip in a 2WD vehicle with reasonable clearance.
746025
