Dual battery controllers
Hi All,
What does everyone find is the best dual battery isolater, I have tried a couple of the more expensive ones and they don't seem to last very long, I am thinking of going back to the old 100amp continious solenoid, at least they are only $20.00 each. Probably open a can of worms here.
Thanks Ross
Reply By: Member - Phil G (SA) - Monday, Dec 12, 2011 at 19:32
In the past 24 years I've only owned 2 isolators - both were made by Rotronics.
The first one was still going after 13 years on my 40series and 61 series landcruisers then the second one is still going after being used in 2 Prados and now my 79series.
I've got the Rotronics MH10 - I'm pretty sure they are electronic - use FETs instead of the old solenoids.
And they isolate as soon as you turn the ignition off, and only consume 8mA when not in use. They cost the best part of $300 - bought mine at Opposite Lock.
AnswerID: 472380
Reply By: Member - Frank P (NSW) - Monday, Dec 12, 2011 at 19:38
Four years into my Redarc SBI, no problems with it.
Draws nothing when not in use.
Frank
AnswerID: 472381
Follow Up By: Member - Phil G (SA) - Monday, Dec 12, 2011 at 21:19
Gday Frank,
"Draws nothing when not in use"
Your Redarc may be different to others!!
Have a read of this thread. I'm assuming your 4 year old Redarc would also not isolate until it has hit 12.5V. To fix the problem, the latest Redarcs cut out at 12.7V to minimise the lost power.
FollowupID: 747182
Follow Up By: Member - Frank P (NSW) - Monday, Dec 12, 2011 at 22:22
Hi Phil,
Ahem ...blush ... yes, you're right. I meant after it had clicked off, but even then I'm still "a bit wrong"!!
I will measure the voltage when it drops out after switching off the engine. It cuts in at 13.2V - I believe the old ones cut in at a higher voltage, so on that basis I might have one that cuts out at 12.7. I hope so.
Also, I presume the module on the side must be monitoring the battery all the time so would be drawing a few milliamps. Not "nothing" as I said, but I hope pretty small, about the self discharge rate of a typical lead-acid battery, one would hope. I haven't found anything in the Redarc documentation that specifies that.
Still, I'm happy with it.
Cheers and Merry Christmas
Frank
FollowupID: 747188
Reply By: Mick O - Monday, Dec 12, 2011 at 19:39
A search of the forum might have prevented the can of worms Rossco lol. It's a popular topic alright and one that is a needed consideration given that just about everyone 4x4ing and travelling this country with vans, trailers etc relies to some extent on power. I'm a big fan of the Redarc products because they have robust products built in Australia to meet our needs and a great service network Australia wide.
I've reviewed the units I've purchased and usedHERE - Redarc review
Why I chose what I did and the research I undertook is also outlined HERE - Ute build
Just be aware that a simple solenoid may not adequately charge a modern day battery in the manner in which the manufacturer intended possibly resulting in reduced capacity and life. There are a lot of good products on the market so do your research and identify something that suits your needs.
Mick
AnswerID: 472382
Reply By: Ray - Monday, Dec 12, 2011 at 20:01
I just use a 180 amp circuit breaker. No problems.
AnswerID: 472385
Follow Up By: Ray - Monday, Dec 12, 2011 at 20:02
Must add that it is ignition operated.
FollowupID: 747164
Follow Up By: Bonz (Vic) - Monday, Dec 12, 2011 at 22:19
you mean solenoid Ray?
FollowupID: 747187
Reply By: The Bantam - Monday, Dec 12, 2011 at 22:34
What exactly is the reason for failure.
There are a whole pile of design factors that lots of people don't seem to want to talk about, or persistantly claim aren't an issue.
issues such as surge current on connection of the two batteries, and how that is to be managed.
In my view there are lots of dual battery controllers out there that have insufficient current rating for the way they are installed.
AnswerID: 472395
Reply By: MartyB - Monday, Dec 12, 2011 at 22:38
I have made a few of these kits, all work well. Site Link
AnswerID: 472396
Reply By: LeighW - Tuesday, Dec 13, 2011 at 07:58
I also use a Rotronics unit and have found it to be extremely well made and reliable. The Rotronics units are also made in Australia.
LeighW
AnswerID: 472412
Reply By: Member - Serendipity(WA) - Tuesday, Dec 13, 2011 at 08:38
I have the dual battery isolator and battery monitor from Sidewinder 4x4 accessories - he is a business member on this forum.
http://www.sidewinder.com.au/page79.html
Great product- I have had it for 3 years now. Once I left the ignition on overnight to have a flat primary battery - with the battery monitor there is a switch to start off my second battery - so easy. Whole unit was easy to fit and very small and compact.
No affiliation just a happy customer.
Serendipity
AnswerID: 472415
Follow Up By: steved58 - Tuesday, Dec 13, 2011 at 17:05
I second that have sidewinder without battery monitor or start switch working great after 5 years and in second vehicle A very good product at a reasonable price also just a happy customer
steve
FollowupID: 747262
Reply By: Fatso - Tuesday, Dec 13, 2011 at 18:07
G'day Rosssssss,
I've had 3 different solenoid set-ups & have had no trouble with any of them.
They were all fitted by the same auto sparkey.
The first one had a very heavy duty solenoid that would isolate the axillary battery when the ignition was off & while cranking the starter.
The second one I had worked the same way, but had a light duty solenoid. It looked more like a relay that you would use for accessories. I can't remember the load capacity, but it was no where near the first one.
The advantage of the first one that was that I could disconnect the earth off the start battery & drive around using the axillary battery as the main battery. This produced a faster charge, if needed. I couldn't risk doing that with the light duty solenoid in case the draw from the battery exceeded it's capacity. I still never had any trouble with that one though.
The third one is a redarc solenoid type.
It's OK so far & works no better than the other 2 I have had.
There may be some technical things someone is going to come forward with about these 3.
If it came to the crunch I would say the first one, with the heavy duty solenoid, was the most practical. This is simply for the reason that you could start the car & then isolate the start battery putting all the charge straight into your axillary battery.
Right from the start I have avoided those computerised jobs & gone for simple systems. This was also the advice of the auto sparky I use. He told me that it wouldn't take long to figure out how your batteries were going & that with the heavy duty solenoid I could easily modify the system to suit my demands for charging.
These days my demands on the batteries are not as great as we move more often & the redarc seams to work fine.
Fatso
AnswerID: 472447
Follow Up By: Fatso - Tuesday, Dec 13, 2011 at 18:09
Sorry, I should have added that I had the heavy duty setup for 80,000 & sold the car, the light duty setup for 180,000 & sold the car & the redarc for 30,000 & counting.
FollowupID: 747268
Reply By: pickle - Tuesday, Dec 13, 2011 at 19:16
Another with two Rotronics over the years. Not a problem with either.
Dave
AnswerID: 472454
Reply By: Cuppa - Tuesday, Dec 13, 2011 at 20:47
Solenoids & Voltage sensitive Relays (VSR's) like Redarc's SBI 'Smartstarts & similar have given good service for years & continue to do so BUT there are now newer & better products that will allow your batteries to be charged more fully & faster than the alternator can via a VSR. I am referring to DC to DC smart chargers. These will charge house batteries to 100% compared to the alternator's best of 70% -80%, giving greater capacity when you stop. They also allow proper charging of differing types of batteries.
I am building a camper (ex telstra Patrol with canopy) & just bought a Redarc BCDC1240 - Combined Solar Regulator & DC to Dc charger (40 amp).
Cost is a lot more than $20, but it depends what you want/need.
AnswerID: 472463
Reply By: Rosss- Tuesday, Dec 13, 2011 at 22:20
Thanks everybody for your info, at this point in time I think I will go with the Redarc, should have bought this in the first place 2 years ago, I won't name the ones I have had the trouble with but they are mentioned in replies.
Cheers Ross.
AnswerID: 472472
