Monday, Dec 26, 2011 at 13:53
Hi PSD2
guess what I am posting now has answered my own question.......and thanks for steering me towards the answer...
In summary is it best to say that if you will always only be on Telstra Next G (3G) then a dedicated 850 antenae is the best...if however you may change carriers one day then the multi frequenct antennae is a good all rounder to save a further expense in the future if one changes networks for any reason?
From "Whirlpool"
3G
There are several 3G networks operating in Australia. 3G frequencies are usually specified as UMTS/HSDPA or WCDMA frequencies on the mobile phone specifications.
Australian 3G bands:
•850MHz (Telstra, Vodafone) – Exclusive 3G band
•900MHz (Optus, Vodafone) – Re-uses the 2G 900 band for 3G in rural areas
•2100MHz (Telstra, Optus, Vodafone, 3 Mobile) – Exclusive 3G band
and
Telstra NextG
NextG is Telstra's 3G offering. It operates on the 850 Mhz frequency in all areas (with some busy areas more recently using 2100Mhz for extra capacity). For full NextG support throughout Australia, you should get a phone that supports UMTS 850.
If you do not use a phone with 850 Mhz 3G support, the Telstra/Three joint network known as 3GIS will be used on 2100 Mhz 3G within
Metro areas. This is NOT known as the marketing term "NextG". Telstra customer access to the 2100 Mhz network will cease in future, at some point no earlier than January 1st 2012.
I am more than happy with the RFI multi band anternnae for my purposes and they have performed
well quite some distance out...and I accept that a dedicated antennae would perform even better
Thanks & cheers
748156
