Monday, Jan 09, 2012 at 10:34
I don't say that I would never use a properly formulated oil flushing product......after all they ( the good ones) will simply be very heavy dose of the same or similar things that will be in oil any way......BUT, I would have to have a very good reason to use one...not just FUD or marketing.
Certainly I would not be using a solvent or
fuel as an engine flushing agent..and there are a number of reasons for that.
1. the solvent or
fuel will remove any residual oil film and may in fact promote abrasion.....so in the short time the solvent is in the engine there will be NO lubrication at all, and it may take some time, many minutes for the fresh oil to displace the solvent and recoat the all surfaces....the solvent will persist in nooks and crannies, dead end channels and between & behind components for quite some time.
From the time the parts are prepared for assembly, under normal situation our engines are NEVER run without lubrication..even if it is just the residual film.
2. there are many internal parts of the engine that while designed to resist oil, may be badly affected by solvent contact, friction and corrosion resistant coatings, seals, gasgets, sealant products and plastic components
3. Of course as mentioned, dilution or contamination of the proper lubricant is a real issue......Um think how much fluid remains in the bottom of your sump and in various channels when you drain.........It can be argued that the solvent or
fuel will evaporate out of the lubricant with heat......yes this may be true, but this takes some time, by then the damage is done
4. The solvent or
fuel used may in fact not remove lots of the deposits people think it will, at least not in the time it is in the motor.
Anybody who has cleaned
old engine parts should grasp this concept......some of this gunge you can soak all day in solvent, and it goes nowhere till you scrubb it with a brush.
Anybody with an interest or experience removing stains, marks or deposits off almost anything will understand that the best starting point is the solvent that material was originally carried in to where it has been deposited.
Most simple glues, paints, stains, and other crap fix to the surface, by the material becomming too concentrated in the solvent carrier to remain in solution and be carried away, thus they adhere to the surfaces.
All the deposits in our engines where once carried in oil.....thus oil is the best solvent to remove them.
If we keep our oil relativly clean ( the impurities in low concentration in the solvent) we have made the first step to a clean engine........a good additive package in that oil, some time and heat will do the rest.
Hope I have not raved too long.
749383
