Cleaning Fuel Tanks
Submitted: Thursday, Jan 05, 2012 at 16:28
napalm_999
Hey all,
My diesel Navara has had one too many dodgy fill ups and the
tank has become contaminated with just too much
water and algae that my last
fuel filter lasted a whole 8000 km’s before literally starving the pump of
fuel under acceleration.
I’ve done some research on the
forum here and other
places on the internet and have identified the mould Hormoconis Resinae as the culprit causing a massive power loss the engine. The
fuel lines are more like a 100-year-old smokers arteries and the
fuel just can’t get through.
So health care has so far been replace the lines and drain the
tank.
What I’m wondering is what’s the best way to clean the
tank? I’m gonna take the
tank out of the car but what’s the best way to clean it out? I’m guessing it’s in pretty bad nick internally.
Also, a final contentious question... should I start using additives to prevent this in the future?
Matt
Reply By: Member - Vince M (NSW) - Thursday, Jan 05, 2012 at 16:48
If your got the algae, its hard to remove it properly & when it dries out it is near impossible to remove from the walls but the chemical to use is Trichloroethylene its a solvent used in the marine/mining/aircraft industry as a parts cleaner etc its a bad chemical health wise so take care but it will remove it all & yes use an additive but the additive may cause you problems as algae is normally in old stored
fuel (boats get it all the time) due to no movement etc & the additive starts to break it down & it blocks everything
good luck
474124
Reply By: Gobumpy - Thursday, Jan 05, 2012 at 19:20
Hey Matt
Once
tank is remover strip all fittings and sender unit than give it a good blast with a pressure cleaner through sender hole and filler neck hole even some degreaser wont hurt once your happy with how clean it is poor 4 or so litres or ACETONE in and give it a good shake around acetone seems to get rid of the
water left over from pressure washer. This process is the exact way I clean diesel and hydraulic tanks on trucks cranes and earth moving gear. Oh tip out
water and acetone after each step. Let dry and recheck.
Scott
474147
Follow Up By: Inflataduck - Thursday, Jan 05, 2012 at 22:21
Scott the tric is non flammable & will evaporates the
water twice as quick & normally does not affect rubber fittings like acetone & cleans twice as good, we use to use acetone, but the tric dissolves the algae with no residues
749101
Reply By: napalm_999 - Friday, Jan 06, 2012 at 11:54
Tric sounds like the way to go. Any suggestions as to where you get sucha chemical?
474206
Reply By: Allan B (Member, SunCoast) - Friday, Jan 06, 2012 at 14:46
Hi Matt,
I have no expertise in cleaning mould from diesel tanks but I would issue caution about using either acetone or trichloroethylene.
Acetone is highly flammable and its vapour will go off like a bomb if ignited. Take great care to use it in limited quantity, in the open, and
well away from ignition sources.
Trichloroethylene is rather nasty stuff. Toxic, carcinogenic and inhaling its vapour can cause extreme reactions and even death. See
here for a Material Safety Data Sheet or Google it. Disposal is a further problem.
Frankly, I would be looking for another more friendly solution.
474216
Reply By: Brian 1 - Friday, Jan 06, 2012 at 16:36
Pull the
fuel tank out and take it to a radiator repair
shop to have it inspected and cleaned.
Brian
474225
