refillable compressed air container/can
Submitted: Sunday, Jan 08, 2012 at 19:11
ThreadID: 91096 Views:4711 Replies:6 FollowUps:10
Hi All
I'm looking for a refillable air container, for blowing around laptop keys, filters,cleaning parts etc. Would like to be able to fill it using my on board compressor on the Troopy. I have found refillable aerosol cans for paints but don't think they would fit the bill.
Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: Fatso - Sunday, Jan 08, 2012 at 19:27
I was talking to a computer repair man a while back & he uses cans he gets from somewhere that are specifically meant for cleaning computers. He reckons it cost $15 worth of cans to clean a computer.
Please don't fly off the handle if he got that wrong.
Anyway I suggested he get a compressor & he said the pressure was not high enough.
So I suggested a divers air tank. They have a huge pressure.
He gave a positive response to that & said he would look into the economics of it.
I guess you need dry air for cleaning electronics.
Good luck with it
Fatso
AnswerID: 474410
Follow Up By: Member - Josh- Sunday, Jan 08, 2012 at 20:29
I would be concerned about moisture from a normal compressor. Big W sell the cans you are talking about. I carried one when we travelled for my laptop.
Josh
FollowupID: 749332
Follow Up By: Witi Repartee - Sunday, Jan 08, 2012 at 21:22
I just give the wife a straw.
FollowupID: 749341
Follow Up By: Mick O - Monday, Jan 09, 2012 at 00:54
Witi.
Oh man that's good! (You're obviously not familiar with the Pocket Rocket!)
Lyndon,
On the serious side, I've usually just used the onboard compressor tank to blow any crap out of the key board, cab and tent. You can fit these relativly inexpensively these days. Mulit purpose and can also be used to blow up tyres!
Plenty of options about.
Cheers Mick
FollowupID: 749359
Reply By: ross - Monday, Jan 09, 2012 at 00:54
Those $12 mattress inflators pump out a fast stream of air with the small nozzle attached.
AnswerID: 474429
Follow Up By: Member - lyndon NT - Monday, Jan 09, 2012 at 21:26
hadn't thought of the air mattress pump, even have on "somewhere" will have to give it a go.
FollowupID: 749457
Reply By: desray (WA - Monday, Jan 09, 2012 at 02:03
Very easy to convert a old used fire extinguisher with a few brass fittings, they are also pressure tested.
AnswerID: 474430
Follow Up By: Member - lyndon NT - Monday, Jan 09, 2012 at 21:36
Thanks Mate
Another good idea, perhaps the most versatile one. I think I would need a tap and die though which I don't have.
I would be a bit concerned about overcharging and putting a fitting through my head!
Lyndon
FollowupID: 749459
Reply By: Robin Miller - Monday, Jan 09, 2012 at 09:09
Just having a good hose and some fittings to our spare tyre works well for us Lyndon.
Its amazing just how many little jobs and even bigger ones like blowing dust out of car and air cleaners etc get done with this simple arrangement.
Bonus being that it doubles as a spare for ARB air compressor.
AnswerID: 474443
Follow Up By: Member - lyndon NT - Monday, Jan 09, 2012 at 21:33
Excellent idea Robin! I would like to be able to use it inside my unit though, wonder what the fairer sex would say if I wheeled in a wheel from the Troopy with 80 pounds in it! :-)
Was hoping to blow out an air conditioner that has a blocked drain tray, though I think the air mattress pump might do the trick.
The Tyre would be great for air filter though. What fitting do you use and where did you get therm?
Lyndon
FollowupID: 749458
Follow Up By: Robin Miller - Tuesday, Jan 10, 2012 at 07:56
Once you implement the idea Lyndon all sorts of possibilities emerge as the capacity is enormous > 60lt , we can dust off the whole car with just 15psi drop.
I just use a cheap long 6mm plastic hose for distance but I have seen others use a cheap wheel barrow wheel as a portable container.
Fittings to tyre need to be screw on , mine came from a short truck tyre extension stem - but have seen lots of screw on extension cables in shops.
One of the best fittings is on the Bushman/Dr Air tyre deflators.
Mostly you don't need this , but if your cleaning electroinc PCBs etc , its good to squirt a bit of air into an open glass jar just to check for water condensation
first - not usually an issue from service station air but if you pump up tank from car pump in high humidity you can get wet air.
FollowupID: 749479
Reply By: vk1dx - Monday, Jan 09, 2012 at 09:28
Hi Lyndon
Fatso got it in one. I used them for cleaning inside lots of equipment. Just $15.
Jaycar aerosol can
Under no circumstances use a pump that does NOT remove moisture to clean anything electronic. Use the one for the tyres and you may just as well hose the insides of the computer out with water.
And then you can use the time that you would have wasted in building or adapting a pump etc into doing something positive like 10oz weight lifting in the shade and the cricket on TV. Or better still a line in the river.
AnswerID: 474444
Follow Up By: vk1dx - Monday, Jan 09, 2012 at 09:34
An option for small jobs:Solder Sucker & Blower Bulb
FollowupID: 749379
Reply By: The Bantam - Monday, Jan 09, 2012 at 12:23
There are a number of things that can be converted, fire extinguisers, gas bottles, and there are some smallish tanks available for use with on board air.
I have a converted 4.5Kg gass bottle I use as a quick portable source of compressed air for " technical purposes"
I have a "T" piece at the top with a female nitto on one side and a male nitto and a valve on the other.
If I pump it up to 90Psi that gives me plenty of air to blow out a projector when I change the lamp for a client without having to drag a compressor arround.
I fill it from my workshop air which is pretty dry. it takes about 30 seconds to fill from my 90psi workshop air feed.
If ya converting gass bottles, the thread varies, some have plain BSP threads some have BSP gas which has a more rapid taper.
Ya better off with a bottle that has a standard BSP thread as you will only get a turn or two of a standard BSP in a BSPT female and getting a tap to cut in these bottles is hard work as they are hardened stuff.
You will need to remove the various fuel specific items like valves, taps & safety devices, and flush the tank well with water.
Because LPG contains a putrification agent, no matter how well you clean the bottle out, the air will from time to time give a whiff of that fake putrid gassy smell.
A mate has a very large gass bottle as the reciever for his workshop air, and once every now and then he gets that whiff & its been in service for over 20 years.
NOW to the moisture issue.
As I said my workshop air is pretty dry..I've made sure of it.
If you want to pump up off a bare unfiltered compressor, yes there is an issue.
BUT, if you pump up then allow the bottle to cool well the moisture will drop out into the bottom.
then make sure you use the tank upright with a short hose & trigger blower.
once in a while invert the bottle and blow out any residual moisture before pumping up again.
If it realy worries you run the air thru a filter reg on the way out of the bottle and let the bottle cool well.
AnswerID: 474465
Follow Up By: The Bantam - Monday, Jan 09, 2012 at 12:28
Just to clarify, there are 3 BSP threads you may encounter on gass bottles.
Standard paralell BSP, standard plumbing BSP tapred, and BSP gas, BSP gass has a very steep taper...the female thread looks obvioulsy conical, more so than BSP taper does.
FollowupID: 749400
Follow Up By: Member - lyndon NT - Monday, Jan 09, 2012 at 21:45
Thanks for the info. Not sure if I will give the idea a go but do appreciate your time and effort.
others might well read your info with interest as well.
Lyndon
FollowupID: 749461
