Tuesday, Jan 24, 2012 at 13:33
How big can you go with 2 inch lift - 33 comfortably.
You can go bigger but rim offsets can be needed.
Legally depends where you are , I refer to Vic.
Most only allow 15mm bigger than standard , but the definition
of standard varies. Most think its the compliance sticker ,
however it actually means bigger than biggest fitted to that
model car.
In GU handbook one version uses much larger 245/85/16 tyres and
15mm bigger that technically allows you to go 33's.
Also you have to consider how wide , not just big.
I have several sets for my GU and like narrow tyres , so I use
whats called 34inch or 255/85/16 which are available in BFG KM2.
These just scrap on the dumb front mudflaps when turning , however
the mudflaps can be re-worked easily to push rearward the mount blot.
If I had wider ( 285/75/16) they touch on the inner guard.
To prevent this I use 6mm offset spacer plates with that set.
Go 16inch steel rims if you can as it makes it easier to lengthen the footprint
and belt them back into shape.
OFFSET - relates to where the
wheels touch the discs.
Negative offset means the outside of the
wheels sticks out further, wider track.
Rims come in different offsets - I use 7in Trak 11 steel rims which have
a 10mm negative offset , standard Alum
wheels tend to have zero offest.
(These rims weigh 4kg each less than 8in steels, and 1kg more than standard.
Issues
1/ when you fit larger diameter
wheels you raise the cars centre of gravity
and even Patrols eventually fall over so to compenstate having the
wheels further apart (negative offset) helps.
2/ The diesels have trouble turning bigger
wheels, so engine mods/tranfer case re-gearing are best, espically if an auto.
4800's no issues with power.
3/ Big offsets , big tyres, heavy rims are hard on wheel bearings and hard on
fuel use.
Conversion example
255/85/16 means tyre diameter is 255X85= 217mm
217mm X 2 = 434 mm
434mm + rim of 16 inches(407mm) = total of 841mm
841mm = just over 33 inches
475883
Follow Up By: Member - MUZBRY(Vic) - Tuesday, Jan 24, 2012 at 16:32
Thanks Robin.
How have you and your loverly wife been?
750923
