Digital Video Camera's
Submitted: Friday, Apr 05, 2002 at 00:00
ThreadID: 915 Views:2772 Replies:8 FollowUps:1
When you go 4wdriving, camping, touring etc, one of the most important items that you chuck in your vehicle is a camera. Isn't it?
I am condemplating a Digital Video Camera. I would be interested to hear your comments (good, bad indifferent) on the equipment that you have.
Maybe ExplorOz could do an unbias road test on Digital Video Cameras?
Reply By: Bill - Friday, Apr 05, 2002 at 00:00
Hi Rod
I use a Sony digital video which has a memory stick. At the end of a trip, I go through the video, select suitable shots and transfer them to the memory stick (press of a button). These can then be downloaded to my PC for storage, enhancing etc and then printing. Stills can also be taken directly onto the memory stick by the way but I find transfer from the video to be the best. I also bought a 12volt charger - about $150 - very useful if you are away from 240volts for a while.
AnswerID: 2648
Reply By: Definate110 - Friday, Apr 05, 2002 at 00:00
Hi Rod,
A Digital Camera is one of the best investments that i have ever made! They put a whole new life into taking photo's. They are instantly viewable, and of course deletable. If i could have my time again i would have bought the Cannon Powershot G2....AWESOME! (I have a Kodak DC4800). If you want to print the pictures make sure that you get at least a 3 Megapixel camerera.
Take a look at http://www.dpreview.com it is IMO the best place on the web for ALL things in Digital photography.
Good Luck.
SeYa
Warwick.
AnswerID: 2654
Reply By: Nigel - Monday, Apr 08, 2002 at 00:00
We've had a Canon A20 (still camera) for a while and in hindsight a sony digital video camera would have been more useful, but we still make good use of the Canon. Being able to take 80-100 shots and then only having to print the 10-15 good ones certainly saves money and lets you try creative things.
AnswerID: 2676
Reply By: Sam - Tuesday, Apr 09, 2002 at 00:00
Rod
goto www.videocamera.com.au
they have a section on all the different makes and models. And they have a buyers guide aswell.
I can't quite remember whether or not they have a model comparison section.
Hope this is of some use.
cheers,
Sam.
AnswerID: 2708
Reply By: royce - Wednesday, Apr 10, 2002 at 00:00
Sony Mavica is the go. A pocket full of 'floppies' and take hundreds of pics on the road. No need for cables etc. I have used one all over Oz with my travelling science show.
AnswerID: 2730
Reply By: Geoffrey - Sunday, May 05, 2002 at 00:00
Hello Rod,
did you get a digital video camera?
If so what did you get and what made you buy the particular model?
AnswerID: 3353
Follow Up By: Rod - Monday, May 06, 2002 at 00:00
No not yet. I'm not in a rush, and it's a bloody minefield.
Thanks to all those who have responded.
FollowupID: 1364
Reply By: Geoffrey - Tuesday, May 07, 2002 at 00:00
It seems to me that many didn't understand the question Rod.
In 'digital video cameras' the format all the major manufacturers have chosen is 'Mini DV' for domestic use.
In addition Sony also make a format called 'Digital 8' which performs to the specifications of Mini DV but uses the older style 8mm tape.
If you are totally new to video cameras Mini DV is the way to go,
however if you have had an 8mm 'Handycam' in the past you may want to consider D8 because it will play your old tapes .
Cost wise the D8 format is the cheapest to get into.
As far as the ability to take still photos with digital video cameras they all can do it with varying degrees of ease . Most of the Sonys have a memory card called a 'memory stick' onto which stills can be directly loaded and downloaded onto your PC .
I will be interested to read your decision.
AnswerID: 3382
Reply By: Rob - Sunday, May 26, 2002 at 00:00
Another option is a digital camera such the Canon Ixus 300 which can take mini mpgs as well as jpegs depending on the amount of memory.
Also look at the cost of the storage medium,memory stick,cf card,mini drive as this may have a bearing on your purchase.
AnswerID: 3831
