Monday, Feb 06, 2012 at 11:08
Firstlly start by thinking connercial and buying your oil where truckies do and in 20l drums.
The transport industry uses oil in huge volumes, and the engines we have in our 4wds will also be in the lighter trucks.
so look at
fuel depots, truck stops and diesel spares stores...although some of the good diesel oils are available in 20's from the auto discounters.
secondly stay with the major oil company brands.....this is possibly the tightest spec'ed and most conforming family of ils there is.
don't be fooled by the price in 20's...the 4/5 litre retail market has a solid mark up.
there will be a variety of specs listed....but "JASO DH1" in the trump card in this group opf specs.
15W40 is generally the required or appropriate viscosity, do not be tempted to go for a thicker oil, it aint necessarily better.
the top 3 oils in that market are
mobil devlac, shell rimular and
caltex dello.
All are diesel spec mixed fleet oils, and meet a wide range of spec's...you can also run these in your petrol motors very nicely.
there are a couple of oils that are "GLOBAL DH1" spec but dont meet "JASO DH1" spec..these will be fine for older diesel engines, but not for the newer ones.
On matter that is important is certain diesel oils are not suitable for use with diesel particulate filters.
At least one of the penrite oils is not suited to DPF engines, too much potasium apparantly.
Remember ALL the oil companies have detailed oil spec on line these days.
For your own peace of mind, look in your owners manual and find the oil spec's, then look at the on line oil company spec and match up the specs.
Remember look for that JASO DH1 spec, all oils will comply with a range of spec, and likewise vehicle manufacturers list a range of suitable oil specs.......
personally I use dello 400, and i can get that ordered in at almost any
caltex servo for arround the $130 for a 20.
All the top 3 can be had for arround the $100 a drum if you
shop arround and are prepared to travel for it.......as I say don't be foolled by the price try and buy any of these retail in 4s or 5s and you will be paying up with the fancy retal brands.
Check those specs
477096
Follow Up By: patsproule - Monday, Feb 06, 2012 at 12:01
Pay $92 / 20L for Delo 400 Gold at the local
Caltex Distributor /
fuel supplies yard.
752272
