Fitting a Delphi cav 296 diesel filter
Submitted: Wednesday, Feb 08, 2012 at 18:07
navara07
I was given a delphi 296
fuel filter and was wanting to fit this to my ford
ranger pk 2010 3 Ltr turbo diesel for a little extra protection of contaminated
fuel. Is there anything I should be aware of when fitting this filter to my car.
Thank you.
Reply By: lindsay - Wednesday, Feb 08, 2012 at 19:51
If you are placing on filter in line with the other one and they are the same microns, you are wasting your time. As when the
fuel gets filtered in the first filter only clean
fuel will flow into the second filter and unless you have a failure in the first filter. This is highly unlikely you will achieve nothing. Running two filters in this way is a fallacy. You would be better off by plumbing them in parallel and therefor increase the filtration area, decreasing the flow through each filter. If you really want to improve things and make it cheaper to maintain, is to use a 795 element instead of a 295 and have a good sediment bowl at them bottom of it,. You could then run it by itself.
477302
Reply By: Member -Pinko (NSW) - Wednesday, Feb 08, 2012 at 20:21
You should read this article on pre filters.
Water Watch System - Responsive Engineering
www.responsiveengineering.com.au
Stan
477304
Reply By: olcoolone - Wednesday, Feb 08, 2012 at 22:39
I think Lindsey meant a 796 filter.
It's a good idea to run a primary filter on any CRD engine and is what most are doing..... the factory filter is about 2 microns and anything above that for a primary is OK.
If you do get a dose of something bad a primary filter will hopefully catch most it before the factory filter; meaning instead of getting stuck somewhere with a blocked main filter you can bypass the primary and travel on..... then if the factory filter gets blocked you have done as much as you can.
A factory filter will flow more then enough
fuel for you engine even if it becomes semi blocked.
A Lindsey said the most important thing is the sediment bowl, if you do pick up some
water the
water trap of the factory filter will only catch and hold so much.... once full
water will get in to the injection system...... adding a larger primary sediment bowl in theory you can filter out more
water and hopefully catch it all before it's to late.
Using a primary filter is not going to hurt and only can benefit the
fuel system.
477315
Reply By: Member - Serendipity(WA) - Thursday, Feb 09, 2012 at 07:01
The only concern with adding a second filter is affecting the flow rate of
fuel. Make sure you check what flow rate your engine needs and what flow rate the filter can deliver.
Modern common rail diesel engines use the
fuel flow to cool the
fuel pump. IF you starve the
fuel pump of
fuel it will not get cool enough especially in those critical times when you are giving it heaps. Not sure how much your
fuel pump costs but I was quoted $10,000 to replace
mine. Sounds like a lot so I try and make sure I never actually find out if that price is real.
Other than that there are a range of prefilters that you can use. A
water trap filter comes to mind as probably one of the essential ones to get - and I believe they come with an alarm (I am yet to save up for one).
Best just carry spare OEM filters with you. I have a CAV filter and have left it in the shed.
Manufacturers just make it harder nowadays to have a better car.
Serendipity
477323
