Using house solar panels
Submitted: Saturday, Feb 18, 2012 at 11:03
2009phil
Hello,
I've got a large near new solar panel left over from renovations to my pergola, it just wouldn't fit back on the new roof without major modifications. I was wondering if I could use this to charge my camper batterys?. The panel hasn't got anything written on it but the sparkie tells me its 190 watts and there are no 12volt regulators available to handle it. I'm interested to hear from anyone who has used one.
Thanks in advance
Reply By: oldtrack123 - Saturday, Feb 18, 2012 at 11:17
Hi Phil
The wattage is not a problem ,but the output voltage of the panel may be
Can you check that with the panel in
bright sun & with no load on the panel?
478055
Reply By: sweetwill - Saturday, Feb 18, 2012 at 12:09
hello phil.
Iv been using one for years now, just alligator clamps straight to the battery, I Must admit that I have to keep an eye on the battery's ,I run an engle from the battery along with the usual charging of phone,and using them for lighting,the panel itself would be about one meter by half a meter the batteries are lifeline 105? they are 5 years old now always in the Ute and being charged when i am travelling I hope this was of some help. oh by the way the solar panel was $20 from a garage sale cheers Bill.
478059
Reply By: The Bantam - Saturday, Feb 18, 2012 at 12:58
In principle there is no problem at all.
the main concern is the voltage of the pannel.
most pannels on housing or remote area power are 24 volt.
As above
bright sun multimeter will show you if the no load voltage is above 24 Volts...guess what...a 12 volt pannel may ahve a no load much higher tha 12 volts 18 volts perhaps but it should not get above 24.
If it is a 24 volt pannel you will need a switchmode or a MPPT regulator that will take the 24+ Volts and output a nice regulated 12 ish Volts.
As far as there not being a regulator available to do the job...rubbish
A mate of
mine built a solar powered christmass tree for a client last season with 4 x 180 watt 24 volt pannels charging a large 12 volt battery bank thru a MPPT regulator..he used the 24 volt pannels because they were so much cheaper.
478061
