12 volt fridge
Submitted: Saturday, Feb 25, 2012 at 23:02
Cajun
Hi can anyone recommend a 12 volt fridge that has a low current draw,and good insulation around 40lt size.
thanks Cajun
Reply By: nowimnumberone - Saturday, Feb 25, 2012 at 23:55
of course we can
weaco 40ltr
478664
Follow Up By: didjabringabeer - Sunday, Feb 26, 2012 at 00:12
Engel 40lt
754216
Follow Up By: gbc - Sunday, Feb 26, 2012 at 07:16
evakool 40 :)
754222
Follow Up By: P and JM - Sunday, Feb 26, 2012 at 12:56
Either the New Evakool 40 Ltr or the Engel 40 Ltr. have both as
well as a 47 Ltr Evakool with no complaints.
Cheers P&J
754238
Reply By: thumper-darryl - Sunday, Feb 26, 2012 at 05:04
To expand on this slightly. Jayco offers an upgrade from the RM 2350 fridge to a Waeco CR110 Is this a necessary upgrade and pro's and con's.
478669
Follow Up By: wombat100 - Sunday, Feb 26, 2012 at 13:58
From experience- I don't think it would be an 'upgrade' to the Waeco (Dometic) CD110.
I think it's a backward step.
754239
Follow Up By: thumper-darryl - Sunday, Feb 26, 2012 at 14:00
That is what I thought. Thanks
754240
Reply By: Nickywoop - Sunday, Feb 26, 2012 at 07:02
You will not be able to go past the Australian made Trailblaza built in Caloundra.
No need for fancy insulation rugs, which are required by some makes, because they lack insulation from new.
Trailblaza are used by the Australian Army in some of the most adverse
places in the world where we will never travel.
Indestructable, ask anyone with one.
Nick
478670
Reply By: darter - Sunday, Feb 26, 2012 at 09:33
I just purchased a Engel 40 Litre MT 45 series II a few days ago.I did quite a bit of research into all makes around 40L.Basically they are all quite good.With the 'Trailbazer' they very best.But one has to consider what fridges suits one best.I found the shape and size to be a very important factor-the Engel suit me best when I factored that in to my decision-I can fit it in both vehicles I own.
Also Engels have been around for 45 years-the seem to have a good reputation on these outdoor forums.If I was doing super extreme desert trips-I'd get a 'trailbazer' as
478677
Reply By: AlbyNSW - Sunday, Feb 26, 2012 at 10:06
Check out the Bushman they rated very
well ( first or second, depending on how you read the results from the last 4WD comparo) and you don't need a bag on it , they supply one only for protection from scratches.
Waeco was the other top performer in the test. I have one of each and happy with both but the best thing about the Bushman is that the electronics board is able to be easily replaced yourself ( plug and play) for around $100 should you have a problem, which I believe is the cause of the majority of fridge failures. I like that I can fix it in the bush and keep going with minimal disruption. My Waeco has been a good reliable fridge too.
No affiliation etc, just a happy customer
478680
Reply By: MEMBER - Darian, SA - Sunday, Feb 26, 2012 at 10:50
As mentioned above, Trailblaza may
well be the world beater in efficiency via insulation - seems they are are aimed at the 'tough use', frugal power supply market. Various insulation thicknesses available - 125mm is common - that makes for a very bulky fridge, even in the small storage capacities, but they seem a very robust unit. When running, the power draw is probably the same as the other fridges, but they wouldn't run as often. They cost more than comparable Waeco's and Engels etc., because they are hand built by Aussies !
My Waeco 60L is ok for our travel formula, with power supply rarely being a problem in our rig. It runs nicely now, since being back to an agent for a warranty repair, is a mass produced plastic product and needs 'pyjamas' (more $$) to get up to half adequate insulation efficiency.
478687
Reply By: pepper2 - Sunday, Feb 26, 2012 at 11:36
i have a bushman,works
well,keenly priced,great aftersales servive,my mate has an engle,main difference is that mates ebgle gets turned off (power disconnected) until morning and the temp only rises about 2 deg by morning ,(eg if at -5 c at night will be about -3c in the morning ) my bushman temp rises quickly when power is off,so it must run at night, the other thing is the engle will freeze everything where ever it is in the fridge my bushman really only freezes the bottom half of the compartment when on max freeze.
478692
Reply By: snailbait (Blue mntns) - Sunday, Feb 26, 2012 at 19:51
HI CAJUN
I have a brand known as AUTO FRIDGE
This fridge sells a lot in north QLD as you put it on while driving and then turn it off overnight
This means over the 24 hrs it is very low power usage
It is a eutic fridge which has a bag of Brine and it frezez the brine into ice and then keeps cold over night
I have had no trouble with the fridge workings
I have used this fridge all around Australia
They are made in Botany NSW
Terry
478752
