Toyota 100 series IFS oil seals
Submitted: Wednesday, Mar 14, 2012 at 17:29
jonl
Hi, would anybody how hard is it to replace the front diff axle oil seals in the Toyota 100 series IFS it is a 05 model.
The seal has just started to leak a bit.
Thanks.
Reply By: Member - Tony H (touring oz) - Wednesday, Mar 14, 2012 at 18:38
Can i suggest you pose the same question on www.lcool.org (free to join) with due regard to this site (exploroz) .... I'm sure you will get a more definitive answer there....
480375
Reply By: fisho64 - Wednesday, Mar 14, 2012 at 22:35
are you sure its the axle seals and not the CV grease breaking down and leaking out? After about 100000k's the grease starts to thin out and looks just like diff oil.
Give it a good degrease and steam clean then check again. I thought same as you on
mine, turned out CV's needed repacking.
480391
Reply By: Member - Richard W (NSW) - Thursday, Mar 15, 2012 at 06:34
jon,
Interesting yours has gone.
I also have a 2005 model and my right front went last weekend however I'm getting my mechanic to do the job as the front locker also needs fixing.
As said about LCOOL.
480399
Reply By: jonl - Thursday, Mar 15, 2012 at 09:19
Thanks for the information, it is the seal leaking as the c/v boot is dry and a few inches away so I will clean it up and see how much it leaks.
480406
