What happens with gas in sealed batterys??
Submitted: Wednesday, Mar 28, 2012 at 14:57
ThreadID: 92842 Views:2627 Replies:4 FollowUps:0
Probably a dumb question- but here goes anyway.
I understand that when batterys are charging, they expel gas- probably hydrogen.
OK- in sealed batterys- where and how and if does the gas go ???
Cheers J&D
Reply By: Notso - Wednesday, Mar 28, 2012 at 15:17
As long as the charge rate is not too grossly above normal the gasses recombine.
This link explains it.
Battry Gasses
AnswerID: 481625
Reply By: Member - Warrie (NSW) - Wednesday, Mar 28, 2012 at 21:32
My reading of other data is not to exceed 14.4 volts or so. Above this hydrogen forms at the cathode - the negative terminal. Its production will start to destroy the grids inside the battery. Yes, I just read in the above link that the gases will recombine - but the damage has been done. I imagine that if you left your charger on at say 15 volts for several hours you will damage the battery permanently.
Waeco recommend a voltage limiter to be connected in series wth the charger for the fridge. Of course theirs costs an arm and a leg so hit the net. Maybe try a CTek.......W
Warrie
AnswerID: 481676
Reply By: oldtrack123 - Thursday, Mar 29, 2012 at 22:42
First of . do not be mislead by the term "sealed"
They are not fully sealed but are valve regulated
The electrolyte is in a paste form with additives that cause the gases to recombine in normal charging , if the charge rate or voltage is too high the gases do not recombine & are vented via the valves/
correct charging is required for long life
Overcharging will lead to paste drying out & short life
AnswerID: 481807
Reply By: blown4by - Friday, Mar 30, 2012 at 22:44
They are not fully sealed.They are fiitted with a small breather. Some have a short clear plastic tube connected to it.
AnswerID: 481930
