Hydrogen Injection !!!!!
Submitted: Saturday, Mar 31, 2012 at 13:15
Member - John
G'day, I know I am opening a can of worms and all comments gratefully appreciated.
I have been told that Hydrogen kits are available that when used on petrol or diesel engines will give up to a 40-50% increase in
fuel economy and also an increase in power.
Now I am sure that the claims can not be true, but does anyone have first hand experience with Hydrogen, good or bad. Thanks in advance.
Reply By: garrycol - Saturday, Mar 31, 2012 at 13:32
I have also heard that Pigs do actually fly and that Hyclones work.
481973
Follow Up By: Member - John - Saturday, Mar 31, 2012 at 13:39
Garry, I was going to mention Hiclones, but figured some else would.......... LOL
757260
Follow Up By: Allan B (Member, SunCoast) - Saturday, Mar 31, 2012 at 14:00
Pigs WILL fly before Hiclones will work! .... FDL
Even though hydrogen can theoretically give some boost it is not practical or economical, and can you imagine what the combustion temperatures might do to valves etc?
Mind you, Joh Bjelke-Petersen was all for it.......Don't you worry about that
Click here
(and for those outside of Queensland, Google "Joh") LOL
757262
Follow Up By: Ross M - Saturday, Mar 31, 2012 at 15:31
If you ask the manufacturer of Hiclones and look at their profit figures you will find they are very successful, as a money earner.
No good in an engine intake though.
The success of Hiclones works on one principle, just as long as everyone supports the same delusion all is ok.
PS the BiCarb cell running to break down
water does work and it does give more economy and power, works in a 2H engine I have seen.
Not sure about the corrosive nature of the gas mix cos it is Oxygen & Hydrogen. Most seem to forget the presence of the Oxygen for some reason. and a backfire type situation could rearrange some items in the engine bay. Think Hindenberg.
Ross M
757266
Follow Up By: Allan B (Member, SunCoast) - Saturday, Mar 31, 2012 at 17:53
The success of the Hiclone business rides on the principle of "There's one born every minute".
757278
Follow Up By: "crack-a-tinnie" - Sunday, Apr 01, 2012 at 10:06
Do you realise, if "pigs could fly", bacon would go up............
757340
Reply By: garrycol - Saturday, Mar 31, 2012 at 14:58
Hydrogen suits internal combustion engines very
well and it runs
well - if you ran it like LPG it would be a great
fuel.
The issue is where the Hydrogen comes from - at present it basically needs to be created by electricity. Hydro electricity or nuclear or solar/green - no issues however the systems referred to in the original post normal generate it by electrolyses with power from the car alternator and the hydrogen is fed into the engine like LPG fumigation with a diesel.
The problem is that physics laws means that energy cannot created or destroyed and as such the engine will have to burn more energy to turn the alternator (extra load) than will be released from the hydrogen when it is burnt - each process in the chain looses energy through heat which is lost.
However hydrogen fumigation with hydrogen stored in a bottle will work just as LPG fumigation works - the issue is where does the hydrogen come from - has to be made as it does not normally exist in a free state.
Garry
481979
Follow Up By: Member - John - Saturday, Mar 31, 2012 at 16:01
Garry, hydrogen fumigation is what I am referring to. The hydrogen is made from
water and is not stored but injected as soon as it is made. Early days in the discovery process, I still think it can't work............
757268
Follow Up By: ross - Saturday, Mar 31, 2012 at 22:31
John ,this is where it all falls to bits.You cannot make enough electricity on board the vehicle to make enough hydrogen to get any benefit.
If it was viable, all of the big car companies would have been all over it years ago.
The claims that it can bring 40-50% savings are a
warning sign.If they tell lies like that,then you cant believe anything else they say.
These kits and all other sorts of
fuel saving devices are always trotted out each time the price of
fuel spikes.
757305
Reply By: Notso - Saturday, Mar 31, 2012 at 15:33
I think the system he is talking about uses a electrical system to Hydrolise the
water splitting it into Hydrogen and Oxygen.
I'd say the amount of energy used to split the
water into it's components would far outweigh any increase in power.
481980
Follow Up By: Member - John - Saturday, Mar 31, 2012 at 15:57
Notso, yes, I am referring to that system. Still looking at relevant information etc. Thanks for your input.
757267
Reply By: murrayman - Saturday, Mar 31, 2012 at 16:51
Hi john, a few years ago i built a hydrogen system for my 80 series petrol gas land cruiser. It consisted of a 1 litre plastic container, a pair of extruded platinum plates inside the container wired through a switch to the auxillary battery. Add 1 litre of
water, 2 tea spoons of carb soda and when you turned it on it looked like a glass of salvital it bubbled that hard. I then ran a hose to the intake just before the throttle body. My biggest problem was controlling the power consumption. It would start of using about 3 amps and after 10 minutes it would be pulling 20 amps. I do believe it made a difference to the performance and i would only turn it on when towing my caravan up a big
hill. i then bought a turbo diesel cruiser and went no further with it. I believe this technology should be explored further and i have heard of them being fitted locally to large semi trailers. Who would have thought when you spend 700 thousand on a brand new New Holland header it will run on chicken bleep . A mate just bought one and it has 2
fuel tanks, 1 diesel, one blue
fuel which is basically liquid fertilizer. We need more people to think outside the square a bit. The govt will never support it because how do they tax
water, if all the vehicles ran on
water there would be nothing in it for them. I read that the first ever internal combustion engine ran on hydrogen, not sure if its true but who knows. cheers mm
481982
Follow Up By: Member - John - Saturday, Mar 31, 2012 at 17:32
mm, thanks for the input, from what I have read so far, 25-30 amps is all the power needed to get enough gas for injection. That doesn't seem to be a lot of power for a potentially large increase in engine power. I am not looking for the increased power, looking to get better
fuel economy. Thanks once again.
757275
Follow Up By: Allan B (Member, SunCoast) - Saturday, Mar 31, 2012 at 17:55
John, perhaps you should look at the maths
here.
757279
Follow Up By: Member - Chris & Debbie (QLD) - Saturday, Mar 31, 2012 at 19:09
@ murrayman, I think you will find the New Holland is not running on two fuels.
From what I have read the blue stuff is basically liquid urea but it is injected into the exhaust system after the turbo and is used for polution control.
Chris
757287
Reply By: pop2jocem - Saturday, Mar 31, 2012 at 17:08
Now I'm not sure what gas was produced but many years (like about 30+...lol) ago a guy drove into a workshop where I was employed at the time. He had an early Landrover, from memory about a series 2 or 2a. Anyway, mounted on the front he had a large cylindrical contraption that apparently used charcoal in some manner to produce a gas that ran this vehicle. May not have been hydrogen, it was way too long and too many stubbies ago but according to him it worked
well you just had to
camp now and then and collect the charcoal from your
camp fire.
Pop
481984
Follow Up By: Allan B (Member, SunCoast) - Saturday, Mar 31, 2012 at 17:46
Hi Pop, They were a war-time alternative to petrol, known as Gas Producers. As you say, they operated by combusting charcoal to produce carbon monoxide (and some CO2) which provided fuel for petrol engines. Clumsy contraptions with all sorts of problems but they did provide an alternative fuel. The charcoal needed to be of good specific quality and leftovers from a
camp fire would be unlikely to be of use.
Here is a link to a paper presented to the Engineers Australia which may be of interest. Acknowledgement to Don Bartlett 2008.
757277
Follow Up By: Allan B (Member, SunCoast) - Saturday, Mar 31, 2012 at 18:22
As a matter of interest, another alternative employed during the war years was by the South Australian Gas Company (and possibly others) who operated normally petrol vehicles with coal-gas. The vehicles had a large gas-tight bag on the roof filled with coal gas which was the same gas as reticulated to homes at the time.
757284
Follow Up By: Member - Scott M (NSW) - Wednesday, Apr 04, 2012 at 11:58
pop, if you read Kurt Johanssons' autobiography, he details in the end his retirement travels around Australia in a coal gas powered station wagon - it used to be (or still is) in the
National Road Transport Hall of Fame.
757542
Reply By: Rockape - Saturday, Mar 31, 2012 at 18:29
John,
I know someone in
Brisbane and by that I do know them
He made his own generator and ran it on the engine.
The end result was a fail. At least he tried it and will never wonder about the end result.
And no you haven't opened a can of worms you just seek a result. From the info supplied you can gather your own conclusion.
RA.
481988
Reply By: The Bantam - Saturday, Mar 31, 2012 at 19:16
Yes this has been discussed in various
places, my understanding of the issues are thus.
Yes there is the problem in the net loss in energy due to the energy required to generate the hydrogen.
What we need to understand is fuel is an energy storage medium, it has to be generated, most of the fuels we now use were generated over a long period and are very energy dense...any way.
There is the problem of generating sufficient hydrogen on a continuous basis to be usefull in a reactor small enough to be practical....remember the
water needs to be carried too
There is the problem of despensing the hydrogen and metering it.......to be of any real use the hydrogen needs to be generated in a consistent way and in volumes that meet needs.
This is all very problematic in the simple systems, because they run at very low preasures and have no capacity for storage.
If the hydrogen generated is controlled by varying the plate currents, the generation and passage of the gas is not immediate and thus it will lag demand.....and people complain about turbo lag???
The coal/timber/rubbish gasifacation systems used during the war are a very different prospect....during the war they were very crude.....there has been a lot of work done on them since, If done
well it is a very very clean and efficient way of burning stuff, particularly waste.......but they are not all that
well siuted to mobile use.
What we should be doing is using waste gasification to burn all sorts of rubbish and generate electricity.........but no one in government seems interested.
481992
Follow Up By: Member - Jerry C (WA) - Saturday, Mar 31, 2012 at 23:50
Hi John,
A couple of years ago there was an article in one of the weekend papers in
Perth that talked about a QLD transport firm running either a double or triple Semi on a weekly round trip from
Brisbane to
Perth bringing fresh vegtables west and picking a load of seafood from Esperence on the return trip to
Brisbane. The article went on to say that it made a difference of about one gear in performance and a cosiderable fuel saving over one year.
The trucks used a Hydrogen injection system produced by a company in
Adelaide,
I enquired about a system for a Prado D-4D which at that time was about $3000.00
A colleague of
mine has built a Hydrogen generator himself which he then fitted to his wife's small Hyundi
sedan which she drove from
Melbourne to
Meekatharra. After acouple of years in Meeka it is currently running around
Perth. I believe that it is now about version 3.
757312
Follow Up By: The Bantam - Sunday, Apr 01, 2012 at 08:51
Yeh there are plenty stories about....but a conspicuous lack of
well documented sucesses.
The issues remain.
Even if a system is "proven to work", is it realy cost effective, in comparison to more conventional alternatives like "diesel gas", "
water injetion" , various fuel suplimentations or simply not bothering.
757332
Reply By: Whirlwinder - Sunday, Apr 01, 2012 at 18:48
Hi John,
Now that all the "experts" have had their say let me give you the facts.
I have a hydrogen system on our 1HZ with an aftermarket turbo in our 80 series and have had for about 18 mths. It was sold to me as an experimental set up, not "plug & play" and it took me a while to get it figured out.
On the first trip, day one, I got an improvement of 17% and that continued for 3 weeks. I even did one day with it on and followed the next day with it off then back on the following day. I continued to get almost exactly 17% improvement.
BUT, it is something that you must be prepared to fiddle with to keep it performing
In the last month or so I noticed the 17% become 5% so I flushed the set up according the instructions and I expect it to return to 17%. I also have hope to reach 20% on our next trip in September.
It is true that the alternator producing 30 amps uses more power than the hydrogen produces but that is irrevalent. It is the presence of hydrogen (and a bit of extra oxygen) that causes more complete burning of ANY fuel in the internal combustion engine. It is visually evident on the back wall of my garage. Prior to the hydrogen generator I had circle of soot about 1m in diameter. When I fitted the generator I cleaned the wall and now have soot in about a 400mm circle. Smaller circle = less soot = less unburnt fuel !! It DOES work.
If you would like more factual detail email me at "toian@spin.net.au".
482107
Reply By: Robin Miller - Sunday, Apr 01, 2012 at 19:29
Essentially a waste of time
John.
You can get many things to produce a burnable fuel and inject it into an engine intake , the only practical one being your normal gas conversion but even thats marginal with gas to petrol ratio of less than 2:1 these days.
482116
Follow Up By: Whirlwinder - Sunday, Apr 01, 2012 at 21:09
Robin,
Normally you make good comment but unless YOU have tried this then YOU really don't know.
I have tried and still use it and I know it works (even if it requires fiddling and determination).
It might even work on you Patrol. My email is above if you want the facts.
Ian
757392
Reply By: Member - Bucky - Wednesday, Apr 04, 2012 at 04:03
Reply By: Member - Bucky - Wednesday, Apr 04, 2012 at 04:10
And another
Click here
Bucky
482275
Follow Up By: Member - John - Wednesday, Apr 04, 2012 at 06:35
Bucky, thanks, will follow up, John
757530
