Friday, Apr 13, 2012 at 08:05
One thing and above all.
Please DO NOT max out your towing capacity.
If you expect any sort of off road capability you need to keep
well under the rated GVM of the vehicle and
well under the towing capacity.
Even if you don't want to go "off road" proper, keeping
well under your GVM and towing capacity, will allow respectable highway performance and far better
fuel economy.
Remember the rated maximum towing capacities are just that and are in truth only fit for a short low speed trip to the local tip or
boat ramp and on smooth paved surfaces.
There are any number of stories and pictures of vehicle rear chasis failures when towing off road and nowhere near rated towing capacity.
Also note that many of the currently marketed vans are designed to be the biggest thing you can possibly tow with a particular catagory of vehicle.
As has been discussed on this
forum and others, many of these "big as you can" caravans have to be managed very very diligently to keep them within the legal specs
One of the first things you should look at is the ATM of the van and its tare weight.....that will give you the payload....some of these vans have less than 300Kg of payload and that disapers very quickly when you start adding accessories and putting stuff in a big van.
Then look how the specified drawbar weight of the van and the rated maximum drawbar weight of the vehicle compare.
Its not what people want to hear, but that is how it is.
What is safe, comfortable and reasonable to tow is far smaller than most people want to know.
If you want any sort of off road performance and that includes reliability from not breaking stuff, ya need to keep any vehicle to under 2/3 of its GVM and half of its towing capacity.
482938
Follow Up By: Member - Redbakk (WA) - Friday, Apr 13, 2012 at 09:08
Excellent advice........also add Kedron to your list.
Going off road also means that your caravan gets covered in dirt as
well (especially red dirt) and is subject to some damage and so after a while it starts to look that way.
And so you really need to ask yourself...." what do I really mean by off road?"
Some people, like myself, have an ordinary road van with what they call a "dirt pack" which while we stick mainly to the black top, it allows us to tackle some dirt sections that are reasonable AS long as you take it carefully and so we can still some "offroad" without punishing our vans too much BUT in time even this will take it's toll.
Hope this helps.
758179
